Old 01-12-2013, 07:25 PM
Hajjy Hajjy is offline
Mein Auto: X3
Auto transmission
I have a 2008 X3 3.0SI. It has 77,000km on it. I brought it in to a dealer complaining about a vibration that I noticed every time I would coast from say 70kph down to 0kph. Mainly occurred as I let off the gas approaching a red light. The vibration would occur at 60kph and then again at 30kph. It felt like the vibration was happening as the transmission was downshifting automatically.
After a few visits, and the dealer consulting with BMW directly, they concluded I needed a new transmission. I was taken back. Wow. Luckily I was still covered under warranty.
Has anyone else had a similar problem? Was the dealer milking a warranty claim or was the right fix done?
Old 01-13-2013, 08:26 AM
x3brian x3brian is offline
Mein Auto: X3
The over arching question should be, has your problem been fixed?
Transmission problems on the 07 and 08 models are not unheard of (see sticky) although I do not remember past reports of your specific issue.
If not covered by warranty, I would have first ruled out the cheaper stuff first...differential fluid, transfer case fluid, transmission fluid, drive shaft, u joints and guibo...but if your problem is solved the dealer must have properly diagnosed the issue.
Old 01-13-2013, 06:58 PM
Mein Auto: X3
It is fixed thanks. Vibration is gone. Still dealing with cold start ticking noise coming from the engine.
Old 01-13-2013, 07:47 PM
Mein Auto: X3
That ticking is common for all built before 10/08. Google n52 valve lifter ticking for everything you need for warranty repair. Will most likely require new head.
Old 01-13-2013, 07:52 PM
Mein Auto: X3
Thx Brian. The more I read the more I think ur right. Another trip to the dealer. Hope this is the last.
Old 01-15-2013, 05:05 AM
frankjr8 frankjr8 is offline
Mein Auto: 2008 X3 Wife, 2009 528xi
What was the problem ,since its fixed? curious...
Old 01-15-2013, 07:49 PM
Mein Auto: X3
They didn't say. They sent a note to BMW requesting permission to replace the Trany under warranty. BMW asked for some more tests and based the results it was later approved. So the dealer was pushing pretty hard to just put a new Trany in. Not sure they even new.
Old 01-16-2013, 10:40 AM
AzNMpower32's Avatar
Tar Heel Faithful
Technically it's a remanufactured gearbox but same difference.
Current consumption: Spritmonitor.de
