Old 01-12-2013, 09:11 PM
Punisher9113 Punisher9113 is offline
Mein Auto: 2003 BMW 525i M54 Manual
Suggestions for a new clutch.
I have a 03 525i need to replace the clutch release bearing but I figured I just replaced the whole thing. I'm not sure if I should stay stock or go stage 1, if so what brand to use for performance and longevity while still being reasonable affordable.
Sent from my PantechP9070 using Bimmer App
Old 01-12-2013, 10:23 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You're kidding, right? With a 2.5 liter engine, you need a killer clutch? Go OEM, and make sure the clutch delay valve is removed.
Ask your mechanic if you should replace the flywheel.
Old 01-12-2013, 10:27 PM
Can you enlighten me as to how removing the clutch delay valve would make a "killer clutch"?
Old 01-13-2013, 08:38 AM
CMRTN CMRTN is offline
Speed Racer
Mein Auto: 98' 540i/6
Haha this is great, Edjack is saying that you do not need a performance clutch on a car that doesn't exceed 200 horsepower. Now if you had a 540 and were doing big performance mods then a "stage 1" clutch would be acceptable.
As Edjack said, stay OEM.
And removing the clutch delay valve doesn't make it killer, it removes the slippage and jerkyness the CDV causes.
TRUELY OEM.
Old 01-13-2013, 08:55 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I typed /CDV F3 in the bestlinks for the OP to come up with this:
- CDV delete by removing the manual transmission clutch delay valve or by modifying it (1) (2) (3) (4)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
