Old 01-13-2013, 03:37 AM
vzinic vzinic is offline
Mein Auto: F10 520d
Auto start stop
Auto start stop function in the winter times, when the temperature drops below the set value does not activated.
Can we change the temperature to a high value of example 30 degrees Fahrenheit, the Auto Start Stop does not turn on until the temperature is higher than this value?
Old 01-13-2013, 03:55 AM
tankren tankren is offline
Mein Auto: 116i
you can set it "memory_off" and this function would never work
Old 01-13-2013, 06:06 AM
Mein Auto: F10 520d
No that's not true, if you are driving and switch to ECO PRO, auto start stop will automatically turn on.
But if the temperature is below 3 degrees Celsius, auto start stop will not work.
Maybe it can be programmed to change the temperature much higher.
