Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-13-2013, 08:10 AM
e30325i e30325i is offline
Mein Auto: 1989 325i
no tach or economy gauge
the guy i got the car from said it worked untill he installed after market speakers all around but idk if he was just bsing me..my fuel guage wobbles but the light works..speedo and miles work fine..also no on board computer..ive changed all the fuses..is there any wires under the steering wheel that he may have disconnected cus its a mess under there from what hes done and have no clue where to start..any ideas wld b appreciated
Old 01-13-2013, 10:43 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Sounds like the PO did a real butcher job on the dash wiring. Other than having a shop straighten it out I think your only other option is to dig into the dash, trace wires and reconnect the stuff that was cut, then wire the sound system correctly.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-13-2013, 12:10 PM
downhiller's Avatar
livin large
or the SI batteries died
Old 01-13-2013, 12:34 PM
yea there is all kinds of wires cut and re wired so itll b a job..si bats cld be dead but havnt the means to change them wld a dealership change them and is it gonna cost me a arm n leg
Old 01-13-2013, 03:42 PM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Find a known working cluster and install it.
Old 01-13-2013, 09:54 PM
BMWFatherFigure's Avatar
Old School
Fix your butchered loom first and leave out the sound. Solder and shrink sleeve all joints. Every where he went you follow and repair. Once you have done that then consider a replacement cluster if necessary. Follow all wires colour for colour. Once that is done then turn your attention to the audio 'installation' (I use the word loosely). Check all earths and plugs for damage - ensure they are clean and tight.
I take it the PO was either a radio installer, alarm installer or a farmer. LOL!
Current:
Previous:
Old 01-15-2013, 11:16 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
There is a couple of plugs on the back of the cluster unit that if you hit them with your hand or hit a big bump then they can lose connection. I left my knee panel off cause every now and again I have to finger the back of the cluster to push on the plugs to get it to work again...
Atleast in my case only thing I can do is get new connector plugs and do some surgery.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
Old 01-15-2013, 11:24 AM
ima have to try that he may have made them loose...nice bimmer tho looks alot like mine lol
