Old 01-13-2013, 09:27 AM
podon podon is offline
Mein Auto: Bmw 640d
CIC Graphic
Hi can I have CiC graphic like in the image below?
Old 01-13-2013, 09:22 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Yes, so long as you are willing to swap out your HU_CIC Head Unit for the new HU_NBT Head Unit, which will be a quite expensive retrofit.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-13-2013, 11:32 PM
kon kon is offline
Mein Auto: BMW
Just curious, is it just the CIC Head unit? What about the COMBOX?
Old 01-14-2013, 12:06 AM
tankren tankren is offline
Mein Auto: 116i
3rd generation iDrive HU_NBT makes "combox" be part of it
Old 01-14-2013, 01:48 AM
kon kon is offline
Mein Auto: BMW
I've read about it, that's why I asked, since the combox cable is routed to the trunk area, replacing the HU_CIC would also require the cable at trunk routed back to the headunit area.... so not as simple as swapping the HU_CIC?
Old 01-14-2013, 02:55 AM
I never said it was simple, in fact that is my point. It is difficult and expensive, and I am not sure if the Dealer could program the car afterwards, so it may require swapping the old CIC back in for Dealer programming.
- BMWCCA #446923
- flick
Old 01-14-2013, 04:46 AM
kon kon is offline
Mein Auto: BMW
Just wanted to confirm and not want to assume since i know zero, but one of the local shop that does retrofit did show picture of something that resemble a combox, so if both need replacing, then it should be a simple swap
Old 01-14-2013, 06:12 AM
I am not sure what you saw, but with HU_NBT, the Combox is physically part of the Head Unit, not a stand alone module.
- BMWCCA #446923
- flick
