Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-13-2013, 12:30 PM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
Un bypass heater core
In the process of hooking back up heater. Was wondering what hose's hook up to what pipe on the firewall?
Old 01-13-2013, 03:52 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
You didn't take them off? So you don't know where they go..... look on realoem.com and study the diagrams of the heating and ac system. That's where the hose connection diagram will be.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-14-2013, 08:18 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
1 John 1:9
Mein Auto: E30, Rabbit GTI
Why would you want to do such a thing? No heat to defrost your windows.
Old 01-22-2013, 02:28 PM
dropframe dropframe is offline
Mein Auto: 1990 325i
Heater Connection
Inlet is the bottom one.
Outlet from heater is top one.
Now I need to know the ID of the hose so I can remove the bypass thermometer and connect the hose back together using a connector. Just need to know what size connector to buy.
Old 01-22-2013, 09:24 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
have you determined why it was bypassed in the first place and fixed the problem? usually the pipes on the side of the heater box, but sometimes the heater matrix (like a small radiator) leaks. these cars are 25 years old now
Old 01-23-2013, 10:31 AM
The bypass was a recall fix to prevent heater core blow-out in an over pressure situation. I can live without it. I just need an easy way to accomplish it.
