Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-13-2013, 04:04 PM
DJHayter DJHayter is offline
Mein Auto: 86 325es
transmission fluid change ????
i have an 86 bmw 325es 2.7l I6 i want to do a tranny fluid change and haven't done one on a manual transmission. can someone help me out with how to do it, what fluid to use and how much. thank you
Old 01-13-2013, 05:01 PM
downhiller's Avatar
livin large
theres two plugs on one of the sides of the tranny (cant remember), bottom one drains, top one fills. youll have to check to see what tranny you have since some take different fluid. theres a tag near the front that has the info.
once you got the fluid and drained out the old, put the bottom plug in and fill the top one until fluid starts coming out. then put upper plug in and your done
Old 01-13-2013, 09:43 PM
BMWFatherFigure's Avatar
Old School
Thread tape on the plug to ensure no leaks.
Current:
Previous:
Old 01-15-2013, 03:07 AM
ozosil ozosil is offline
Mein Auto: 323i
I thought manual BMW never require a tranny fluid change, the manual says it lasts a life time. What are some symptoms of this needing to be done?
Old 01-15-2013, 04:55 PM
downhiller's Avatar
livin large
this is why reading the manual is bad. every fluid needs to be changed at some time for a longer lasting vehicle. the manual trannies are a longer service interval, its normally done the same time you get a diff service.
the newer cars are a dealer only service on the trannies. they use a machine that attaches to one of the cooler lines then the other to the radiator and it flushes out the fluid. but thats mainly on autos
Old 01-15-2013, 05:24 PM
Mein Auto: 86 325es
im still trying to find out the fluid i should use i went under and looked for a tag and all i found was a yellow sticker saying special oil HWB BEST NR 8122 467 305 does this help at all
Old 01-15-2013, 05:30 PM
downhiller's Avatar
livin large
whats the production date
Old 01-15-2013, 05:33 PM
downhiller's Avatar
livin large
realoem.com is saying atf for all of 86 manual trannies so dont know.....i would just thrown in some redline mtl.
Old 01-15-2013, 05:38 PM
Mein Auto: 86 325es
driveshaft coupler sizes??
i have a 86 325es manual. how do i know if my tranny is built from 06/1986 125mm outer dia or from 05/1986 110mm outer dia. please let me know
Old 01-15-2013, 06:09 PM
downhiller's Avatar
livin large
on the tag within the driver door, there will be the production date at the upper right hand corner (from sticker writing) itll be the month number/year. 86 was a split year. pre5/86 had the older tranny style, post6/86 had the newer tranny
Old 01-15-2013, 06:16 PM
Mein Auto: 86 325es
01-86 is what it says so i have the 110mm ????? does that help at all with what fluid to put in the tranny
Old 01-16-2013, 06:00 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Best Nr
means order number in German.
I Googled
HWB öl
HWB lubricant, but got nothing. Sure it is HWB ?
Don't take life too seriously; no one gets out alive !
Old 01-16-2013, 04:08 PM
downhiller's Avatar
livin large
http://www.redlineoil.com/product.aspx?pid=51&pcid=7
it does state most bmws
