View Poll Results: Have you replaced the VANOS seals on your 7?
Yes 4 11.43%
No 31 88.57%
Voters: 35. You may not vote on this poll
Old 01-17-2013, 08:16 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
so I have seen alot of people with pre-facelift models doing this and it helping them.... anyone with a facelift model done this or going to do this one??
Old 03-26-2013, 07:04 PM
bmoneyg bmoneyg is offline
Mein Auto: 2007 750 LI
Greetings 7Figuerz
Can you give me some clarification. When ordering the O-rings it says 4 required of each. According to your pics I would only need two of each. Are there two other solenoids somewhere?
Old 03-26-2013, 07:06 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i; 750Li; Yukon Denali
Originally Posted by bmoneyg View Post
Greetings 7Figuerz
Only two on each valve! You should have a total of 4 big O-rings and 4 small ones. One big and one small for each valve.
Old 03-26-2013, 08:03 PM
Thanks for your quik response 7Figuerz.
I apologize in advance if I'm being a PITA. If there is one big and one small on each valve there are only two in your pics in which I would use a total of 4 o-rings. Where I am not clear is where are the other two solenoids for the remaining 4 o-rings.
Old 03-27-2013, 10:05 AM
collins912's Avatar
I'm not 7Figurez... To answer your question the are four solenoid valves on the front of the engine, 2 for each side. His pics were for reference I'm sure. Heres another pic for clarity.
Name:	solenoid valve.jpg
Old 03-27-2013, 04:59 PM
Sorry about that. Thanks for the clarification. Just wanted to make sure I ordered the correct amount and now I know the location of all soleniods.
Old 03-27-2013, 05:13 PM
cbell13055 cbell13055 is offline
Mein Auto: 05 CTS-V
You should totally post a DIY. Maybe get a few pictures. I feel comfortable already doing it, but love to see pictures on how to lol
2008 Jet Black 750i. Sport, Luxury Seating, and Logic 7. <3
Old 03-27-2013, 07:30 PM
collins912's Avatar
Not a problem.
Old 04-29-2013, 12:21 PM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
So if I were to pull the units and replace the O-rings do I HAVE to do any coding or module resets, etc. Or is it as simple as remove a couple bolts, take off old o-rings, put on new o-rings, wipe it down, push it back in and tighten a couple bolts?
Old 04-29-2013, 05:18 PM
Vanos solenoid o-ring replacement
I did not do the coding but did change the O-rings as preventive maintenance. It was pretty simple.
Pull the retaining clips off with some needle nose pliers. Remove the plug (connector). Then take the bolts holding the solenoids on.
Gently pry loose with a screwdriver there is a little groove there. I could not get it all the way out with a screwdriver, so once I loosened it with the screwdriver it used some needle nose to pull it all the way out.
The one by the vacuum pump was not that hard but did look like it would be. Once you pry it out a little with the screwdriver I used some channel locks on and turned it to the 5/6 o'clock position and it came right out. When putting the new O-rings back on I put some oil in a cap a put the small ones in the oil prior to installing them on the solenoid. I ran the large O-rings in oil also. You will see where the large o-ring goes when you remove the solenoid. You cannot put the large o-ring on the solenoid and then install. Large o-ring must be mounted before installing the solenoid. When reinstalling put a rag, bowl pot or something under the solenoids before you install the plug clips. You do not want to drop one like I did. Its aluminum. If you are doing it right after driving have some rags the solenoids are hot.
I had a little oil on the lower front of my vacuum pump. I did have the recall hose fixed and think the o-ring between the pump and timing cover may be leaking. Check that out also. I can see there oil has been leaking because I have soil buildup from oil be on the parts below.
Old 04-29-2013, 06:50 PM
collins912's Avatar
Exactly just that!
Old 04-30-2013, 07:05 AM
Can you elaborate on this? What do you mean you can't put the large O-ring on the solenoid and then install?
Great heads-up about the aluminum retaining clips...yeah dropping one would suck.
Old 04-30-2013, 07:17 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Replacing Vanos Seals, the best and cheapest($25) repair for your 7
He means you put the oiled up o ring inside the space for it on the timing cover. If you put it on the solenoid first you may pinch ; ruin and waste an oring
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 04-30-2013, 08:17 AM
Ahh...also good to know.
Old 04-30-2013, 01:35 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Re: Replacing Vanos Seals, the best and cheapest($25) repair for your 7
I was wondering if this repair will fix rough idling on cold start? And will your transmission shift smoother with this? Thank you
Old 04-30-2013, 06:56 PM
Drb007 Drb007 is offline
Mein Auto: 2006 BMW 750Li
I think I have my Indy talked into trying this in the next couple of days. I'll keep you posted on the outcome. Cant wait to have smooth idle!
Old 05-02-2013, 09:02 AM
For anyone that has already done this. Can you simply pull out the solenoid and replace the small o-ring (which is the one that leaks apparently) without disconnecting it and then put each one right back in?
Old 05-02-2013, 04:35 PM
Once you remove the retaining ring the connector comes off very easy. By not removing the solenoid from the timing cover it may actually take longer to do the job. Plus the wires are not that long.
Old 05-02-2013, 07:44 PM
collins912's Avatar
Nothing to do with tranny shifts whatsoever!
Old 05-02-2013, 08:05 PM
Cannot say it will fix that issue you have. However you may want to consider doing it as a process of elimination/preventive maintenance. You never know. Have you changed your spark plugs, air filters, trans fluid and filter, fuel filter? How many miles do you have on your 7? You may have a vacuum leak also. Do you have any codes? I remember not having my oil cap on good caused my 7 to run rough. Sounds like when something on your vehicle warms up it enables it to idle smooth. Lie something seals when warmed up. Is this your case. Maybe one of the Gurus will chime in also.
Old 09-06-2013, 06:16 AM
fabecton4570 fabecton4570 is offline
AllanB4570
Mein Auto: 2004 745Li
All, can these O-rings be ordered from your favorite parts house or is this a dealer only part?
Regards, Allan
2004 745Li "HiOSilver"
Old 09-06-2013, 06:52 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
These are basically the same solenoids used in hydraulic equipment (liftgates, cranes, etc.) - as long as the temp.range, diameter and oil compatibility are considered when ordering - you can get them from a good hydraulic repair shop (probably even better o-rings that will last forever - at a price). But to save time & money - just get them from BMW.
Old 12-30-2014, 05:42 PM
mgucci745 mgucci745 is offline
Teenage Car Enthusiast
Mein Auto: 2002 745i
How do you guys clean the solenoids? I've read letting them soak in brake fluid works? Some people use compressed air?
Old post but I need an answer lol
This Car Im Driving Make U Feel Some Type Of Way
@V1SUALZ Los Angeles car v1sualz company coming soon!
F*** a lease, drive a e65
Old 12-31-2014, 02:21 PM
chamilun chamilun is offline
Mein Auto: 2008 535 ix
bentley manual always recommends compressed air. People have tried many things with the other styles. sometimes they need to simply be replaced
Old 01-03-2015, 03:21 PM
gammodm gammodm is offline
Mein Auto: 2004 745i
I just blew out with compressed air.
