E46 (1999 - 2006)
Old 01-13-2013, 10:30 PM
hhariri hhariri is offline
Mein Auto: 2000 328i
Fuel Filter Replacement Complications
I used this DIY (http://forum.e46fanatics.com/showthread.php?t=265683) to replace my fuel filter. I have a 2000 328i which happens to take a simple 1 inlet/1 outlet filter. The DIY went nicely until the end when I tried to start the car back up with the new filter in place.
The darn thing refuses to start. I can hear the pump working in key position #2. But when I go to start the engine I hear a clapping sound and see lights flashing. I tried several times but no success. My gas tank is depressurized and has about 1 gallon of gas.
Any ideas what this could be?
Note: I already made sure the filter was installed with the arrow in the correct direction. No leakages either. I'm out of ideas
It is not how fast you go but how well you go fast.
Old 01-13-2013, 10:42 PM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
You did put fuel pump fuse back in?
Atleast i read some instruction to turn key to position #2 3-4 times before trying to start the car. (pump collecting pressure back?) And after that i was able to start the car. It still took about twice longer than normal before car fired up, but it started and worked normally since then.
Mine is 2000 also so shouldn't be difference about that.
Old 01-13-2013, 11:03 PM
Yes I did put the fuse back in. And I did try key to position #2 at least a dozen times (each time I let the pump build the pressure). I wonder if it is due to the depressurized and nearly empty gas tank. I'm going to fill the tank and give it another try. Hope that does it.
Old 01-13-2013, 11:13 PM
heztheone heztheone is offline
Mein Auto: ///M
when u turn the key to position 2, leave it there for 10-15 sec, then go back to position 0. repeat 2-3 times then let her rip, should fire up with no trouble.
no offense or anything, just double check the right fuse is back in the right place
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 01-14-2013, 12:15 AM
I had maybe about 1/4 of fuel when doing mine.
Old 01-14-2013, 05:41 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
what brand fuel filter did you buy? I think some have a regulator on them
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 01-14-2013, 07:12 AM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
Check connections to the filter and make sure you have not reversed the two hoses that plug into one end. Then consider putting in a little more gas. You mentioned the car making clapping noise when you start. So it's not cranking? If its not then the fuel filter is not the issue. I would check the battery and starter instead. Try jumping it and see if the starter engages. It may be as simple as your battery being low.
Old 01-14-2013, 08:07 AM
joegr joegr is offline
Mein Auto: 2002 325i
Originally Posted by hhariri View Post
... But when I go to start the engine I hear a clapping sound and see lights flashing. ...
I think that you and everyone else is hung up on the fuel filter change, but this sounds unrelated. I think that you have a bad battery and that priming the fuel pump was the last straw for it. How old is your battery? Have you tried a jump start?
Old 01-14-2013, 10:21 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Originally Posted by scarede46er View Post
Check connections to the filter and make sure you have not reversed the two hoses that plug into one end..
Hoses reversed is not uncommon. Give serious consideration to this.
Old 01-14-2013, 10:22 PM
Well ya, but OP is not even getting a crank. I think battery is gone.
Old 01-15-2013, 06:48 PM
I'm not getting that from reading his post. Sounds like the engine is spinning without starting.
I could be wrong.
Old 01-15-2013, 08:24 PM
I could be wrong.
This is why I think it's a battery problem " But when I go to start the engine I hear a clapping sound and see lights flashing."
