Old 01-14-2013, 12:38 PM
nitrydr1600 nitrydr1600 is offline
Mein Auto: 1997 z3, 1982 corvette
1.9 cracked head
any thoughts on using block sealer for this problem. car runs fine but coolant in the oil. took the head to get checked and found small crack. no head available around here and thought about a new gasket with sealer in the coolant??????????? Any sucess stories and what sealer did you use?
Old 01-15-2013, 04:04 AM
brock5ga brock5ga is offline
Mein Auto: Z4
Take the head to a reputable machine shop. Depending on where the crack is, it may be able to be welded. The machine shop we use around here does not weld the heads themselves, but send them out to another shop in downtown Atlanta (which most machine shops use) to have them welded. They then return and complete any other necessary repairs. Expensive gasket set and a lot of work to try sealer, which probably won't work.
