E36 (1991 - 1999)
Old 01-16-2013, 03:27 PM
gomfrddy gomfrddy is offline
Mein Auto: 93 525i
94 318i no fuel no spark??? wtf??
need help....checked fuses found the ecm fuse blown, replaced it no change..no fuel no spark...any ideas???
Old 01-16-2013, 03:36 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Cam position sensor or crank position sensor. The ECU can't "see" the engine turning, so it doesn't fire the injectors or the plugs.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 01-16-2013, 03:49 PM
Mein Auto: 93 525i
but i am not hearing the fuel pump buzz???? how do you test the crank and cam sensor? thanks
Old 01-16-2013, 04:05 PM
D'oh, You Kids!
Since the ECU thinks the engine is off (and it is, since it won't fire) it won't turn on the fuel pump except for the initial 2-3 second priming run. If you've already tried cranking it, the line pressure is up and it won't run at all.
Go here:
http://www.bimmerfest.com/forums/sho...d.php?t=466604
Right-click on the "This" in "This one went missing" and 'save as'. It's a Bentley E36 manual. That will take you through the diagnostics of testing the position sensors.
Quotes to live by:
Old 01-16-2013, 06:21 PM
Mein Auto: 93 525i
nice manual!! thanks
Old 01-17-2013, 09:50 AM
Mein Auto: 93 525i
problem solved!!! turns out I had poured dishwashing liquid on the belts because they where squeaking a bit and it gor on the crank and must have gumed up the teeth or the sensor, anyways I sprayed brake cleaner on the crank and started right up...thanks horn!!!
Old 01-17-2013, 12:09 PM
D'oh, You Kids!
Dishwashing liquid? Really?
(next time use belt dressing spray...or better yet, fix why they squeak...tension, alignment or worn belt/pulley)
Quotes to live by:
Old 01-17-2013, 12:38 PM
Mein Auto: 93 525i
Yea it work s good unless you have a cps on the bottom of the crank..lmao
Sent from my LG-E739 using Bimmer App
