E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
I recently got into my car and the clutch pedal dropped to the floor. Their is absolutely no pressure in the system. There is fluid coming from somewhere, I can't really tell. I don't think the master cylinder or the slave are the faulty parts. Any ideas what else it could be?
The car is a 1988 BMW 325i. I have not really done much maintenance to my car, except routine things like oil changes etc. thanks -Nick Last edited by Nick Wilkinson; 01-13-2011 at 10:24 AM. Reason: left out details. |
On my 86 325es it was the master cylinder but i did not have a leak.
Is the leak under the dash, under the hood or under the car? Is the reservoir filled up to the line? Trace the leak back to the problem. |
The leak is coming from somewhere under the car, around the transmission. It is not dripping enough to see where it is coming from. (The problem is I don't really know a whole lot about cars.) All I have is the Haynes manual.
Why do you rule out the slave cylinder as being the problem? (It almost certainly IS the problem).
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Well, I guess I ruled it out because it didn't seem like fluid was leaking from there, however I could take a closer look. And, as I said before I am an amateur in the realm of vehicle maintenance.
It is probably your master cylinder or slave cylinder.
Either one can pack up without any loss of fluid....the early E30s had a major problem with the master cylinder packing up, requiring a replacement of the master cylinder seals and a complete bleeding of the system....I had to do this a few times on my early E30s! |
Its the salve cylinder. The fluid will leak out of the little drain hole on the bottom of the bell housing. Pull the slave and push the rod in, you will know if thats the problem as soon as you do this. It will possibly just fall out also. Same thing happened to me a month or so ago. Make sure you bleed the system up towards the res. Go buy an oil can from a parts store and a 3mm hose and pump the fluid up till you see no more bubbles in the res. and its bled. GL
![]() "I knew a guy who bought a used car through a newspaper. Ten years later...bam...Herpes." |
Bleeding the slave cylinder
I just replaced the slave cylinder on my e30 and I am now trying to bleed the air out. No matter how many times I pump the clutch peddle, no pressure is built. Does anyone know how many times I have to do this? Could there be another problem?
It's your master Cylinder I had the same problem. Very simple to replace did it in my driveway. Don't worry about any leaks there are none I had the same thought. Just the cylinder isn't pushing fluid you're fine just replace it.
Read my post its right before yours it answers your question.
just an fyi, when my master cylinder went the fluid was traveling down the line and outside the car, where it was dripping from where the hard line connects to the rubber line going to the slave cylinder.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines |
What is the price range to repace the master and or slave cylinders on my 325i?
thanks for using search button.
are you wanting to pay someone to do it as well or just to buy the parts and do it yourself? i recommend getting someone to do it, bleeding the clutch without the correct tools is a pain in the ass
I had this issue and had to replace the master cylinder in the dark ......it was a pain in the butt. Good luck man if you have the time to do it, Do the research and do it its a interesting experience.
The E30 is the single greatest BMW in my mind. |
I lost track. How many thread jumpers on this? To OP - change both the master and slave. Both have been used the same number of times.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
| Tags |
| manual transmission |
