Old 01-15-2013, 07:39 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
We should start a "What's this light?" sticky
Because there are a fair number of service lights that aren't in the manual (at least, they're not in mine), and it's a pain to go digging though the multiple posts looking for what one means (unless you're willing to ask and put up with the "Google is your friend" posts ).
I'm happy to throw in a couple of mine that are currently on and not in the manual.
From Left -> Right above
State inspection / roadworthyness / emissions check due (based on time since last one)
Brake fluid replacement due (based on time since last change)
Estimated miles to front brake replacement
Estimated miles to rear brake replacement
And one that's in my manual, but not with the real explanation
Miles until 30,000 mile inspection due
Images from others:
Sunroof anti-trap inactive (hold sunroof button "Up" until roof runs through full range of motion to reset) [via Zeichen]
Edit: If we want, I'll keep adding in as people post
ID:	357782   Click image for larger version
ID:	357783   Click image for larger version
ID:	357784   Click image for larger version
ID:	357785   Click image for larger version
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 01-15-2013, 08:58 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
I'd volunteer the snowflake but being southerly, I probably won't see it again before you do.
This one crops up now and again but is easy to (attempt to) fix on one's own before visiting the dealer (forgive the image quality--not my photo):
It means the sunroof anti-trap function has been deactivated. In most cases this easily corrected by re-initializing the sunroof as described here and here (short version: press the center of the sunroof button [vent position] and hold for 30 seconds).
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-15-2013, 09:51 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
Couldn't we just post the manual.
(Or the relevant pages from the manual that show the lights.)
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 01-15-2013, 09:56 AM
Zooks527's Avatar
As I said in my first post, the first 4 images that I show aren't in my manual.
Old 01-15-2013, 10:05 AM
cwinter's Avatar
Here comes trouble!
Interesting, are you using the paper provided manual? I just looked through the downloaded PDF for my model (2009 3-series, no iDrive) and found all the lamps.
I think the confusion comes in when separating the service lights from the indicator lights. Some of the pictures you posted are on the the "Indicator Lamps" section towards the back of the manual, while others are under "Settings and Information --> Service Requirements" towards the front. In the PDF, the indicator lamps with general service warnings refer to the Service Requirements section. Since you can click on it, it makes it quite easy to find the PDF.
Old 01-15-2013, 10:35 AM
Zooks527's Avatar
I've got the same downloaded manual you have. Spent 10 minutes looking through it this morning for the "roadworthiness" icon and never found it. Looking where you point, yup, there they are.
I will, however, challenge you to find a description of what the car-on-lift means. Even where you pointed, it's just denoted as "service requirements". If you didn't have a heads up that it was the 30k inspection, where could you find out what it wants you to do, net of a visit to the dealer? Similarly, the "roadworthiness" test ends up being used by dealers to remind you that a state inspection is due, but I can't find that in the manual either.
Old 01-15-2013, 10:38 AM
cwinter's Avatar
Here comes trouble!
First off, I just wanted to say I was mostly joking about just posting the manual, clearly people come here regularly wondering about certain lamps and a sticky is useful.
That being said, I recall seeing a lot of explanations about car on lift in the indicator lamps section. In most cases, it was paired with other warning lamps indicating specific service needs. There were a lot of cases though, so clearly this can get confusing quickly. BMW's answer is likely: Just take it to the dealership and they'll make it go away.
Old 01-15-2013, 12:29 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
SOLID
