Exhaust smell in the cabin - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 12-24-2012, 11:52 AM
jay72 jay72 is offline
Mein Auto: BMW X5 3.0d 2004
Hi again all well it seems like my car is falling apart literally.
I have an exhaust smell in the cab and with the bonet open I can see fumes coming out from the outlet side of the engine.
I have have had people say Exhaust manifaold could be cracked or the gascket gone.
Any other ideas before I start to get mechanics to stripp down the side of the engine to fix the problem??
Thanks from MR X5 owner broke!!
Old 01-04-2013, 01:46 AM
Anyone please ......
Old 01-04-2013, 12:29 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Seems as if it would be a cracked manifold or worn out gasket. Can you hear the engine ticking while under the hood from the exhaust manifold side? If yes then you have an exhaust leak somewhere. As far as fumes entering the cabin, again logical because I had a small oil leak after replacing my valve cover gaskets. I though all was well until I could smell a strong burning smell after driving. Open the hood and its smoking lightly on the right bank. I let it cool down, run my hand around back and felt the gasket warped and spilling oil. I used a mirror and thought I felt it correctly during install, but no. The thing is I couldn't understand why the smell would reach the cabin if the odor is under the hood. So my point is is that it is possible to get fumes in the cabin with the recirc on the a/c controls set to auto. If you are getting an exhaust smell its likely the manifold or gasket. The 3 liter diesel is no different from the gas 8 in terms of what exhaust gas smells like in the cabin, so that would be my guess.
Good luck.
Old 01-16-2013, 12:39 AM
exhaust manifold
Well yes you were right and thanks for the heads up.
Exhaust manifold it was. 790 ouch.
Can I ask if you would have any logical reasons as to why it would crack.?
I guess the obvious could be manufacturing fault, however curious to know of anything else could cause it.
Cheers for the response.
Jay
Old 01-16-2013, 04:48 PM
boramkiv's Avatar
Propellers Up Front
Continuous hot exhaust gasses with different fuel additives/types over the years. They try to expand as heat builds, then they cool off. They get rusted and soften over time as the metal wears away, eventually leading to a crack in a weak point or high stress area. Not sure what type of metal it is, but I'm sure it's light to reduce engine weight and can only be prone to cracks much sooner than heavier metals.
Be sure to check your engine mounts too. Excess vibrations can only put it under more stress.
