E46 (1999 - 2006)
Old 01-14-2013, 10:59 PM
Gandi Gandi is offline
Mein Auto: BMW E46 320i 2004
Car trembles during takeoff
I am driving 320i 2004 Model, my car doesn’t have a smooth take off. When I release clutch the car trembles, even if I release the clutch slightly without engaging accelerator.This cause me to takeoff very slowly to reduce the trembling or if i try to takeoff normal balancing the clutch and accelarator the car will tremble jag and go off. It does these only when I take off. I took the car to the workshop to be inspected and the mechanic concluded that I should change my clutch. All the deferential bushing is still ok. So my problem is I am not convinced that the cause of this vibration is clutch. Anyone with any ideas please.
Old 01-14-2013, 11:10 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Does the clutch slip under load ? Do you know how to test it ?
The road goes ever onward....
(R.I.P. Jever)
Old 01-14-2013, 11:39 PM
I dont know how to test the clutch, but i dont feel any change on peformance.
Old 01-15-2013, 12:50 AM
heztheone heztheone is offline
Mein Auto: ///M
drive with a speed of 40mph on 4th gear and kick the throttle all the way down, if the RPM rises and the car does not accelerate, ur clutch is slipping. if the car accelerates slowly and the RPM is steady, ur clutch is ok. did u check all the mounts?
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 01-15-2013, 01:01 AM
I will do the test and give feedback, thanks guys.
Old 01-15-2013, 10:50 PM
I have done the clutch test and the it seems 100% to me, Where else can i look.
Old 01-15-2013, 10:56 PM
Fast Bob's Avatar
Keeping it surreal
If the clutch does not slip, it probably does not need replacing. Find a better mechanic.
(R.I.P. Jever)
Old 01-15-2013, 10:59 PM
Thanks, i think thats the best idea.
Old 08-16-2013, 06:03 AM
[spurt] [spurt] is offline
admittedly SLICK
Mein Auto: 2002 325i (E46)
Did you ever find a solution?
Old 08-16-2013, 06:07 AM
Nothing yet, I was advised about a clutch tweak but only to find out that my car does not have a clutch switch. I am still battling with the irritating trumble during every take-off
Old 08-16-2013, 10:22 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Might be Guibo
Might be contaminated clutch, or bad pressure plate springs.
Old 08-17-2013, 10:35 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Might be either Guibo, as GFF mentioned, or drive shaft center bearing. Those seem to be the cause of 80% of these problems. Check the driveshaft U joints while you are in there.
Old 08-17-2013, 02:41 PM
Fishful Thinking Fishful Thinking is offline
Mein Auto: '04 325ci
I would agree with the contamination theory. I periodically experience the same problem, and I find stop and go driving makes it worse. I fix it by occasionally bedding my clutch, similar in concept to bedding brakes. On a long, empty road, I'll start in 2nd or 3rd gear, revving the engine pretty hard up and down while slipping the clutch. I do not let the clutch fully engage. I'll do this for maybe 10 seconds, then push in the pedal, put the trans in neutral and coast to a stop. I'll leave the pedal depressed for at least 2 minutes to allow the clutch and flywheel to cool before letting the pedal out. The theory is that by heating up the mating surfaces I'm burning off contamination and depositing a smooth layer of clutch material on the flywheel. Of course, I accept no responsibility if you try this and toast your clutch. Good luck.
Old 08-18-2013, 11:48 PM
Thanks i will give it a try and give feed back
Old 08-19-2013, 10:43 AM
SJBimmer's Avatar
Also check your motor mounts.
Old 08-21-2013, 11:55 PM
Guys i am very very very happy i just cant stop driving my car, clutch bedding solved all the problem. my car is driving very smooth and i am enjoying mu ride now. THANK YOU VERY MUCH FOR YOUR ADVICE.
