Old 03-17-2013, 10:00 AM
dcocke dcocke is offline
Mein Auto: 2000 z3 2.3
z3 alignment
I am getting an alignment on thurs. I have read all the old post about alignments. Do I ask for only a front wheel alignment. Some post say there is no adjustment for rear that a basic alignment can do. Thx
Old 03-17-2013, 10:08 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Unless your car has had aftermarket adjustment welded in, there are no adjustments that can be made. Always ask for a 4 wheel alignment (not sure if anyone even does 2 wheel alignments anymore) because it will give you information if something like a rear trailing arm is bent. If your car is lowered, expect the camber to be out of whack (too much negative camber).
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 03-17-2013, 10:39 AM
alignment
Thx much. 2000 z3 with low miles. I do not believe any adjustments have ever been made. Will ask for 4 wheel alignment.
