Old 01-15-2013, 06:28 AM
HMartin528i HMartin528i is offline
Mein Auto: e39
Cool Subwoofer answers
I am looking for a cheap way to wire my subwoofers into my e39. I have the stock radio and love it. I am in no rush to replace it. How would I go about this?
Old 01-15-2013, 06:55 AM
Fudman's Avatar
Fudman Fudman is offline
How can we help if you don't identify what subwoofer you have?
Old 01-15-2013, 07:19 AM
Nline6's Avatar
Nline6 Nline6 is offline
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
Im sure he is asking about "any" subwoofer that is non oem. Could be wrong
Touring the nation, one state at a time
Old 01-15-2013, 08:56 AM
CMRTN CMRTN is offline
Speed Racer
Mein Auto: 98' 540i/6
In the trunk where locate the amp and the main wire harness. This is what you will tap your line into with a line output converter ($20)
What year is your e39?
Do you have DSP
Depending on the year and whether or not you have DSP factors the wire pins.
TRUELY OEM.
Old 01-15-2013, 09:42 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
Search YouTube for BSW installation guide. You'd need an amp to power those separately from the stock amp though.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 01-15-2013, 09:59 AM
Fudman's Avatar
First off, is it a powered or unpowered subwoofer (it better be powered)?
Second, you can take a signal from the amp (see post #4) or you can tap into a speaker wire. However, only certain subwoofers can do the latter. He needs to be specific if he expects any real help.
Old 01-15-2013, 11:45 AM
Nline6's Avatar
Arent most subwoofers powered? by either an internal or external amp? I guess I dont understand what a unpowered subwoofer would be? other then unhooked . Not trying to argue, I just dont see the point in being over technical when you most likely have an idea of the general answer to the question. Specific questions get specific answeres vague questions get vague answers.... maybe he wanted a vague answer?
Old 03-28-2013, 10:24 AM
GQJQ GQJQ is offline
Mein Auto: E39 sport
I have an 02 E39 Msport and my subs just stopped working.. Any suggestions??
Old 03-28-2013, 12:11 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Hofmeister Kink
Mein Auto: 2003 530i/5
Buy low, sell high.
BMWCCA # 430911
Old 03-28-2013, 12:46 PM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is online now
Mein Auto: 03 Ex Cop 530d Touring
Hi,
Anothergeezer - fantastic advice for a good overall financial view !!
GQJQ - can you update with what troubleshooting/fault finding you've done so far please?
Cheers, Dennis!
Old 03-28-2013, 07:38 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Is it Safe to Dance?
Mein Auto: 2001 540i/6
A powered sub just means its a sub, enclosure, and amp all rolled into one product like the Infinity basslink that i have. Unpowered would be a loose sub where you need to go find your own enclosure and amp to use with it. Though im still not sure why he said it "better be powered" Because either way the signal tapping should be the same
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
coming soon:
Bc coils
Jb lwfw
Old 03-29-2013, 05:11 AM
Fudman's Avatar
The definition above is correct. I said "Better be powered" because the stock amp does not have sufficient power to power a subwoofer. You can continue to use the stock amp when replacing the OE 5.25" woofer and tweeters because most aftermarket speaker have greater efficiency (greater output at the same power level) than the OE Nokia speakers. However, if you add a 8" or 10" subwoofer, you better add some power to go along with it, otherwise, you will be disappointed with the sound quality.
Inputting the signal into a powered subwoofer varies, depending upon the brand. Some only allow line level (RCA) inputs. Many subwoofers allow two types of signal input: line level inputs and speaker level inputs. The Infinity Basslink allows both as does my Blaupunkt. The line level input is the same signal you get at the back of a preamp/amp or receiver. The speaker level input is simply tapping into the powered speaker line. The latter approach means that the volume of the subwoofer is directly proportional to the volume of the speaker line it is connected to.
Without knowing specifically what subwoofer he is attaching, we are speculating as to the solution to the problem. Refer to the subwoofer user manual for detailed guidance.
