Old 01-15-2013, 07:57 AM
chrisdaniels33 chrisdaniels33 is offline
2007 X3
Mein Auto: 2007 X3
Window Wiper and Window Washer Fluid Leak
I've been scouring the forum for these two issues... One I need to replace my wipers, and was wondering can I just purchase some from a local parts store? And what are the sizes? May sound like a simple question but the dealer keeps telling me I need wipers specific to my 2007 X3.
Also, I've read a few posts concerning leaks from the Window Washer Fluid tank. One of the pumps I guess they are called isn't turned all the way, and when I turn it to tighten, it stays that way for a day or so, then it loosens itself again, which causes that particular pump to suck the fluid up and out of the tank, so the light for low fluids stays on and it's driving me crazy... Has anyone ever experience this? If so, does it have to be replaced or something?
Old 01-15-2013, 08:47 AM
x3brian x3brian is offline
Mein Auto: X3
Any old wipers will work as long as you change the frame and blade. I believe driver is 22 inches and passenger is 20 inches.
The dealer is a cheaper option though....they sell the rubber inserts for only a few $s but you need the oem frames. Be forewarned though...they chatter like heck unless you clean them really good with rubbing alcohol pads (I use ones from a first aid kit).
For your washer pump it sound like you need a new rubber washer grommet. This is the part that the pump actually sits inside of to stay nice and snug. Also only a few $s at your parts counter.
Common problem. I have had to replace both of my pumps since new on my 09...currently at 108k. I just get the cheapie URO aftermarket $4 pumps now from ecstuning. It's more cost effective.
Old 01-15-2013, 09:22 AM
Mein Auto: 2004 X3 2.5i
This video on wiper replacement is more comprehensive than most, and explains it detail the different attachment types, using just inserts, frameless blades, etc.:
Old 01-15-2013, 09:48 AM
2007 X3
Mein Auto: 2007 X3
Thanks both very helpful...
Old 01-16-2013, 09:39 AM
cagui1223's Avatar
cagui1223 cagui1223 is offline
Mein Auto: 2007 BMW X3 3.0si [e83]
I replaced our windshield wipers with the Rain-X latitude ones, can't recall the sizes though. Our 2007 X3 3.0si was also leaking out of one of the washer pumps. I purchased the washer grommet from the local dealer, cost me like ~$5.00. I also replaced the washer pump but I didn't get it from the dealer since they were charging $80.00 for one. I ended up ordering one from Auto Parts Warehouse:
Washer Pump AutoTrust Gold Washer Pump AutoTrust Gold
Price: $ 28.65
Qty: 1.00
Part #: WREPM371501ATG
FYI,
when I connected the pump, at first I thought I got the wrong once since no water was coming out. It took a few minutes because it was the pump for the rear window. Also, I doubt the original pump was defective yet I still purchased a new one since it wasn't that expensive. No more leaks though!
I changed the part out sometime during November of last year and the vehicle had approximately 88,125 Miles.
Old 01-16-2013, 10:12 AM
2007 X3
Mein Auto: 2007 X3
Thanks I was thinking of going with rain x, and the grommet I am going to pick up one today...
Old 01-16-2013, 11:03 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Chris do your self a favor and do a search on windshield washer pump, there is tons of information there. Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 01-16-2013, 05:13 PM
maxeaus maxeaus is offline
Mein Auto: x3
I just bought one myself, this one comes with pump and grommet, http://www.ebay.com.au/itm/230544938...84.m1497.l2649
2006 X3 3.0D
Old 02-12-2013, 06:24 PM
reed75 reed75 is offline
Mein Auto: 2006 X3
So my fluid tank is now leaking and not holding anything so I'm assuming its this same piece your are speaking about. So how do I replace this? If I remove the tank will I see what needs to happen? Or do I not have to remove the tank to replace this part?
Old 02-12-2013, 09:06 PM
Mein Auto: x3
There is one bolt to undo holding the reservoir in place you cant miss it, its that simple, you will have to pull off the rubber hoses attached to the pumps or you can just pull the pumps off the reservoir, whatever is required.
2006 X3 3.0D
