The X5 SAV Forum
Old 01-15-2013, 02:14 PM
bimmerworld bimmerworld is offline
Mein Auto: X5 2005 Sport
X5 Radiator nozzle?
Does anybody know what this is in the picture attached? The picture is taken from the front of the passenger side. This nozzle-like thing is attached to the radiator and when pushed (under the cap) it blows air. I guess this is used to remove air from the radiator. Is that correct? I tried it for 10-15 seconds and air kept going out. I guess I should continue until water comes out, right. Did not continue before asking you guys. Thanks!Click image for larger version
BMW X5 2005 Sport E53 M62
4.4i V8 DOHC 32V AWD
Old 01-15-2013, 10:07 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by bimmerworld View Post
This nozzle-like thing is attached to the radiator and when pushed (under the cap) it blows air. I guess this is used to remove air from the radiator. Is that correct? I tried it for 10-15 seconds and air kept going out. I guess I should continue until water comes out, right. Attachment 357816
I can't say for certain (due to you NOT having ANY information in a signature or listed as to WHICH of the 3 engines you may have on your 05 X5)...but I highly suggest NOT to keep releasing the "air" from that schrader valve.
More than likely, you are releasing the R-134A refrigerant from your AC system. Again, I can't say for certain since there's no car info to tell which engine you have and the pic is so close to the valve that I can't tell if it could be the high or the low side. Plus you say that it is running to your radiator? (why would your cooling system have that much air under pressure...it should only contain coolant)
You'll definitely know this summer if you released your refrigerant if your AC will only pump out warm air.
Q {BMW CCA Member #191509}
(SOLD)
Old 01-16-2013, 08:06 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
^6 months later
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 01-18-2013, 02:27 PM
Thanks, QSilver7!
You are right, that was the A/C refrigerant valve. I don't think I lost too much R-134A, but I will probably top it off in the summer. Do you know if that is the high pressure valve? There is another valve near the windshield washer tank close to passenger firewall. I guess that one is the low pressure one. Is that correct?
I have updated my signature with my SAV's specifications. Thanks for pointing that out!
