Old 01-15-2013, 03:48 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
how to test fuel pressure properly?
spaghettidecoder is down and i cant find the bentley on my comp....
what is the proper procedure to test the fuel pump?
i assume the pressure is taken at the fuel rail from the schrader valve but does the car need to be idling, driving, under load w.o.t.?
and what is the accepted value? about 50psi in all situations?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 01-15-2013, 05:15 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
At idle it should be ~ 52 PSI +/- 2 PSI.
I got your PM's last week, wasn't ignoring you, been re-doing my network and building a new computer.
2000 540/6 Slightly tweeked...everywhere
Old 01-15-2013, 05:38 PM
Topaz540i's Avatar
Agnostic Priest
w/e man, ive been bizzy too.
shopping my new system! Ballin on a budget....
infintity basslink powered 10" on the way. Kicker component 5.2's and zx350.4 up next!
so should it stay constant while driving? im wondering if i get bad pressure when im pushing it hard at higher rpms.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 01-15-2013, 05:44 PM
The pressure will only vary a few psi from idle to balls to the wall.
At a constant speed/load the pressure should stay the same.
Old 01-15-2013, 05:51 PM
Topaz540i's Avatar
Agnostic Priest
ok thx. all i could find were people asking the same question but never getting an answer.
I found some old threads about long cranking that got me spooked.
basic sympton is the car turns over a few times before firing but,,,,,,,,,, if you leave the key in pos2 for 5 seconds before igniting it will fire up instantly.
my usual habit is to put the key in and buckle up while i wait for the wheel to lower then fire it up but i do know it takes longer to start if i just shove the key in and twist it.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 01-15-2013, 07:38 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Cross referencing to here in case people need the location of the test points:
- While replacing your spark plugs (1), where is the fuel system pressure test Schrader valve for the I6 (1) and for the V8 (1) (2) (3)
