E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
I'm having ahard time figuring out why my car won't start. (I have the 00 323ci). The one thing that's strange is when I take out the key the radio, dash and windows are still on.
But the worst part is that the car won't start. Maybe the battery's doesn't have enough charge since the windows and everything stayed on but when I try to start the car I don't hear a click from the starter. I get nothing. Can anyone help me. Or call me. If I can't get to work I might loose my job |
If its failing battery, its because some how I still have power after I take out the key. The first thing I'm going to do is charge the battery but its only going to die again cause of this power issue. I have to figure out why my power stays on when I take the key out. The funny thing is it started up fine last night
Having a weak/failing battery can cause all sorts of weird, seemingly unrelated problems. Continuing to drive on a weak battery can also damage the alternator, so it`s a good idea to replace a dying battery ASAP.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Thank godI checked the fuses and it was the starter interlock #14 that was missing. So now should I care if all the power stays on after I take out the key?
I'm not sure about your vehicle, as it differs for each, but some of those fuses are missing for a reason. Chances are, your car never had that fuse to begin with, so it isn't your problem.
Your absolutely right. Let me start from the begin. I bought this car thinking the engine didn't get hot enough because it was a short test drive anyway I bought the car and the temp needle doesn't work so I've always had a fear that the car is overheating or will over heat. Since the temp gauge doesn't work. ( in the process of getting one). I am monitoring the temp on the LCD on the instrument cluster, I always see it in the 110s 112s I'm thinking maybe the fans not coming on. Also I see that that low coolant light was lit. Anyway long story short I need up killing my fan when the problem was the expansion tank. Trying to finger out the problem I took all he fuses out and might have put one where they don't belong.
Fondle your wires behind the fuse box
I always suggest this to cars older than 10 years. Never know
If you'll post the year, model, and manufacture date of your car, someone may be able to take a pic of their fuse box for you to compare to. |
Well the problem with the power staying on, I believe has to do with a malfunction with the ignition. The ignition has 4 positons 1. Off 2. Accessories 3. Prime and 4.start. It seems like I have 5. 1. Accessories 1 1/2. Off 2. Accessories 3. Prime 4.prime 5. Start.
. So which means when I'm driving I can move the key from position 4 to position 3 and it will still say on. Im not sure if its the ignition or something. |
Fuse Chart
