X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
2006 X3 Wont Start
I was out today picking up a new oven and it was around 30 + degrees celsius, when i went to leave the X3 wouldn't kick over, i only hear a single click once then no clicking when trying to turn it over, i tried moving the gears around, take out key, put key back in etc, then i rang road service and they cant even find the starter motor
![]() What dose this sound like, starter motor, solenoid? BTW where can i find the starter motor? I'm assuming its somewhere that is a prick to get to.
2006 X3 3.0D Last edited by maxeaus; 01-15-2013 at 08:39 PM. |
![]() Just posting the ignition lights, anything wrong here im not aware of?
2006 X3 3.0D |
From above, all the intake components block your view, and underneath a drive shaft and other things obscure it.. I think it's a 4+ hr. job to R&R, so you want to eliminate simpler possibilities first. Of reports on this forum that had similar symptoms, the end result has been a few surprising things, such as: - an engine control sensor gone bad and locked out the start protocol - transponder in the key failed - battery tested good still unable to energize the starter (more likely if continuous clicks) It's worth checking Fuse #14 to see if that has blown as it controls the immobilizer and/or the EWS. See: http://www.trapdoor.demon.co.uk/bmwx...use%20card.PDF Failed X3 starter motors are not unheard of but not too common. If the warm weather had anything to do with it, maybe the battery electrolyte evaporated a bit. Battery testing is not a very exact science. I'd charge it up fully and try again before anything else. |
I have two keys with the transponders, last week i went to get in the car and the doors wouldn't open and i had to get in the boot as only that worked, after slicing open the plastic cover i found the small clicker had snapped off hence im now using my spare key, which has been working without issue all week, also i did try the old key to start as well but no luck. - an engine control sensor gone bad and locked out the start protocol....................Not sure how i go about finding this out, code reader didnt show any faults but i have only a simple eBay one. It's worth checking Fuse #14 to see if that has blown as it controls the immobilizer and/or the EWS. See: http://www.trapdoor.demon.co.uk/bmwx................I will check that out as a couple of other people mentioned it could be retlated to the immobilizer.
2006 X3 3.0D Last edited by maxeaus; 01-15-2013 at 11:05 PM. |
So in regards to the fuses would you suggest i swap no 5 (horn) with no 14 and see how that works out?
2006 X3 3.0D |
I have swapped the fuses around and still it wont start which only leaves me with the engine control sensor in that list.
2006 X3 3.0D |
The only way to rule out one of the many sensors, or something else in the electronics, is with the BMW diagnostics at a dealer or well-equiped independent.
Worth the admittedly high price before going to the trouble and expense of removing things to test the starter motor. But don't rule out the battery yet - a battery can fail in a way that prevents even a jump start getting through it. The fact that you couldn't get the remote unlocking to work last week is suspicious - might not have been the key's fault and it got broken while slicing it open. |
Actually the small nodule snapped off in the key, but it still might have been because i had to press so hard because the battery wasn't full power, anyway in a couple of hours i will know for sure with a new battery.
2006 X3 3.0D |
Just to let you all know it was the starter motor that didn't work, has been replaced now and all is well.
Thanks for the help.
2006 X3 3.0D |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
