The X5 SAV Forum
Old 01-16-2013, 02:28 AM
cossie69 cossie69 is offline
Mein Auto: x5
torque settings for rear subframe bolts ???
does anyone know the torque settings for the rear subframe mount bolts that go through the bushes, i am goin to replace the 4 bushes as there shot but i cant find any torque settings any where and any tips would be great i have hired the tool and bought bushes but dont want to go ahead till i get the torque settings , hope someone can help me on this as i have no other way of finding out, best reagrds to all
Old 01-16-2013, 03:25 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Those are torqued to 143 Nm or 106 ft lbs. if using polyurethane bushings, they can be torqued in the air. If using rubber, you should torque while vehicle is on the ground. Alignment should be done afterwards, if not done recently or if bushing were completely gone.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 01-17-2013, 01:10 PM
Mein Auto: x5
thanks so much for the reply pal i can get this done over the weekend now cheers pal
