Old 01-16-2013, 02:36 PM
Mr745i Mr745i is offline
Mein Auto: 745i
I want to install U.S. dash cluster in my Euro version e65
OK people I have a European version e65. I want to change dash cluster to read MPH. My question is, will the U.S. versions read the mileage correctly? Or could I just swap some things over out of each cluster? Im simply tired of looking at a paper than looking at the speed on dash to make sure I'm not speeding or going to SLOW :screwy: help
Old 01-16-2013, 02:46 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
lol... isnt there both mph and kph on the cluster.... i have seen uk bmw like this jut primary (kmh) is on outside ring and mph on inside ring
Old 01-16-2013, 02:52 PM
Mein Auto: 745i
Rage there isn't no MPH at all only km/h!
Old 01-16-2013, 05:59 PM
thats some bull$hit
Old 01-16-2013, 08:42 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
I have a 745 gauge cluster for sale if you wanted to do the swap. Message me if your interested.
SOLD
2003 745Li
Authentic AC Schnitzer Aero Kit inc Front, Side Skirts, Rear, Mirrors, Roof and Trunk Spoilers
Gloss Black Grille and Window Trim
KW Variant 3 Coilovers
22" Interad Turismo Forged 3-piece wheels
Old 01-17-2013, 10:45 AM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
What ever gauge cluster you get you will need to take the electrical board off of your orginal and install it on the new cluster, then reinstall back into the dash.
All of you KOMBI information will be retained and no programming needed.
hope this helps
Nygel
Old 01-17-2013, 03:17 PM
Mein Auto: 745i
@nygal, thanks for the reply. I totally understand and that is what I'm going to do but I'm afraid that the MPH needle want read right. If um going 35 MPH but the needle is on 45mph. Ant thoughts?
Old 01-17-2013, 03:39 PM
canuckdon canuckdon is offline
Mein Auto: 2008 750Li
You could move to Canada
When I drive in the states, I just keep a few conversion numbers in my head. i.e. 50kph is 30mph, 80kph is 50mph, and 110kph is 70mph, and I interpolate for other speeds.
Old 01-17-2013, 03:42 PM
Mein Auto: 745i
that's what I'm already doing. I don't mind speeding but I'll like to no I'm sleeping. In Florida
Old 01-17-2013, 07:27 PM
Nygel's Avatar
everything will be fine. It will work cause the is no calibration difference in the two.
Old 01-17-2013, 07:36 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
I believe your mileage will be affected & you
will get the TAMPER DOT On your cluster ,
Since the VIN & mileage from other cluster
Will not match your car ...
Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 01-18-2013, 04:12 AM
Mein Auto: 745i
basically I have had my cluster droken down looking for bad soldering spots or bad connections. The speed gauge detach fairly ez. I just didn't want to buy U.S. cluster and still have the speedo readings off.
The only thing I am going to change is the MPH gauge. Not any of the electrical parts. Just the MPH gauge.
Old 01-18-2013, 06:41 AM
Nygel's Avatar
pick a MPH and then look at your original cluster and you will see that its the same. If all you are change is cosmetic and mechanical everything will be fine. Paper is correct, that will happen if you do a direct swap of two different clusters.
Old 01-18-2013, 07:55 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
I wish you posted this a week ago. I threw my parts cluster in the trash thinking there were no useful salvageable pieces left.
Old 01-19-2013, 06:23 PM
Mein Auto: 745i
Dang, snoop i could've use those parts..lol
Its all good. I'm going to pick up another cluster ask unit and L7 for the low Monday.
Old 01-20-2013, 01:13 PM
Dan_E65 Dan_E65 is offline
Mein Auto: '06 E65 730d Sport
Why not just code the car to the UK spec?
Old 01-23-2013, 01:51 PM
Mein Auto: 745i
OK folks finally have my odometer reading MPH! Thanks for all the help. Wouldn't have done without U.
Old 01-23-2013, 02:03 PM
Nygel's Avatar
glad it worked out,
Old 01-23-2013, 02:12 PM
Mein Auto: 745i
Old 01-24-2013, 07:59 AM
See-5 See-5 is offline
Mein Auto: E66 750li
Hey
Am looking to do the opposite swap !
My odo is MPH and I wan't it to be only in KM/h
Any one need MPH I can do the swap for him
also if anyone have Km/h odo I will buy it if he wants
thanks
Old 01-24-2013, 08:37 AM
Mein Auto: 745i
I got what u need
And I'll explain how to do the swap without messing with any settings ie) mileage and so on. Lemme no
Old 01-24-2013, 02:15 PM
Thumbs up
I got what u need
that's fantastic .. I will PM you now
Old 01-24-2013, 03:37 PM
Mein Auto: 745i
Here ya go. this euro cluster is up for sale if anyone needs it.
Old 01-27-2013, 07:18 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
Mr745i, I assume you followed Nygel's advice and just swapped the electronics from your original cluster into the US Spec MPH cluster?
hope this helps
Nygel
Nygel, any idea if just overwriting the VIN in the used cluster (via NSCExpert) is sufficient for it to take over the Odometer reading stored in the CAS module? I am assuming the Odometer reading in the CAS is greater than that stored in the used cluster.
The training PDF in the DIY section has the following statement:
"Note: In the case of a used instrument cluster (vehicle identification number is entered), the vehicle identification number can be overwritten up to a kilometer reading of 254 km (158mi). A reset of the permanently stored mileage reading is not possible."
But often I find limitations listed in the training literature are just limitations of DIS and Progman.
Old 02-03-2013, 10:45 AM
I spoke incorrectly above in regards to using NCSExpert to overwrite the VIN. The job does not appear to exist in NCSExpert.
WinKFP has two such a jobs, one for the "internal VIN" and one for the VIN stored in the UIF (User Information Field). Unfortunately the instrument cluster (KOMBI) rejects the change to the internal VIN on a used cluster. You can change the UIF VIN, but you still get the tamper dot. The attached photo shows the used cluster plugged into my car. It took over the correct odometer reading, but lit the tamper dot as the internal VIN's don't match.
I just disassembled the used cluster to the point where I could remove the speedometer gauge, repeat with my original cluster, then swap gauges. They have the same range (up to 260 km/h), so no coding or programming was required. Plus I was able to keep all my original KOMBI electronics.
ID:	360576   Click image for larger version
