Old 03-25-2016, 07:10 PM
rajnair rajnair is offline
Mein Auto: X3
Transmission fluid fill nut damaged/ stripped
After drained the transmission fluid and when I was ready to fill found out the nut is stripped and won't even take the 17mm wrench anymore. The vehicle is on ramp and stuck. Anyone have experienced similar situation and what would be the way out?
Old 03-25-2016, 07:32 PM
rooflessvw rooflessvw is offline
BM and V dub love!
Mein Auto: '04 Phaeton,' 06 X3
A big extractor would work. It already has the hole for you! Vice grips around the edge could work too. Buy a big torx and hammer it in there. Weld a bolt to the bolt. Many ways to skin a cat.
Sent from my Chroma Nexus 6
Zedís dead baby, Zedís dead.
Old 03-25-2016, 08:00 PM
Mein Auto: X3
Thank you rooflessvw
I'll try the vice grip first
Old 03-25-2016, 08:07 PM
BM and V dub love!
Good luck man! The easiest way to remove a stuck bolt is with patience. When you start to get mad, go watch a cartoon and drink a beer.
Old 03-25-2016, 11:05 PM
TomNJ TomNJ is offline
Mein Auto: 2005 BMW X3 3.0i
I'm going to generalize this statement and have it tatooed to the inside of my eyelids.
Hmm... I should probably be patient and think that one through a little more.
Old 03-26-2016, 04:08 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
You can buy a 12 pt gripping socket at Lowes to go over a stripped bolt. They should work well with a larger bolt head like the trans fill.
Worst case you can get it started with a chisel and hammer, too. Buy new bolt of course . Pay for it with a charge card and eat lunch in the BMW waiting lounge
Old 03-26-2016, 04:33 AM
BM and V dub love!
Is yours a hex head or allen head?
Mine was/is allen.
Old 03-26-2016, 04:41 AM
Hex head on both drain and fill on my feb 2006 build E83 M54 automatic transmission
The location was different than some of the threads led me to believe, too.
Both diff drain plugs were Allen heads plugs
Transfer case was hex head bolts.
Old 03-26-2016, 01:45 PM
Earlybird Earlybird is offline
Mein Auto:
Vice grip + elbow grease
Old 03-26-2016, 01:46 PM
Mein Auto:
As for stripped Allen wrench drain plug. Jb weld Allen socket and new plug
Old 03-28-2016, 07:47 PM
Mein Auto: X3
After taking several "breaks" and hand from a friend, the trick was tap on the case and brake loose the nut. Since the hex nut was already rounded, vice gripped on washer
Thank you all for your inputs
Old 03-28-2016, 08:38 PM
BM and V dub love!
Cheers!
aft fill nut
