E34 (1989 - 1995)
Old 01-16-2013, 07:11 PM
bppdx08 bppdx08 is offline
Mein Auto: 530i
Lurch/Jolt and CEL When Accelerating/Heater Not Blowing Consistently
Hello all… Newbie here, so I appreciate you checking out my query. I’ve never been a car person, so bear with my inarticulate attempts to explain what’s going on – I read the “monologue” and will do my best to abide!
I recently purchased a 1995 530i, with an automatic transmission, approx 280k miles. The previous owners installed a rebuilt transmission and new rear brake light wiring within the past year.
About three days after I got it home last month I was just getting on the freeway and accelerating at about 50mph when the car began lurching or jolting, for lack of a better word, and the check engine light came on each time it lurch/jerked and then it would resume accelerating. The car never came to a standstill, but if I’d been in a manual I’d liken what was happening to it stalling, feeling-wise.
This has happened one more time, this week, again as I was on the freeway accelerating and around 50mph.
I checked out the links on how to do a “stomp test” and did it this afternoon. I’m having a hard time figuring out the code. What I was getting looked more like Morse code than the code in the example video (mine was 1-short, 1-long, 1-short, 1-long and then repeating ad nauseum). Maybe I did the test inaccurately? Could the 1 long be more like an uninterrupted 2 pulse? If so, that would make the code 1212, which is the Oxygen Sensor 2. But again, I am just making this up. Here’s a video, let me know what you think?
I also did the dashboard cluster test but am not sure how to interpret the reading or if it’s even relevant to this issue. But I’ll post that too.
Finally, I don’t know whether to consider them related, but the heater has been going off and on for the past two weeks. Sometimes I turn the dial all the way up and there is just no air blowing. Others it blows faintly and cold. Other times it cranks up just fine. There is often a loud thumping in the dashboard area when the heater comes on. Like I said, I’m not sure if it’s related but figured it was worth a mention.
Before you worry that your advice will be in vain since I’m such a novice, fear not. I will be able to get my brother to do the heavy lifting but I need to show him the courtesy of doing the legwork first and trying to take care of what I can. If you can suggest somewhere I can look to learn more about this, or ideas on what the issue may be I'd really appreciate it.
Thanks so much for taking a look at this!_a_
1995 530i, automatic.
Old 01-17-2013, 10:04 AM
Mein Auto: 530i
Hmm, I'm inept. The videos didn't link in my last post.
Dashboard Cluster Test
Stomp Test
Old 01-17-2013, 10:49 PM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, '87 325ic
Check system voltage, battery connections, ground straps. The stomp test seems to be malfunctioning. This car will behave very erratically if it's not getting 12-plus volts. That's the first thing I'd check.
Old 01-18-2013, 05:03 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: 535i
I also think you have a bad electrical connection, and it could be directly related to the blower fan not working properly as well as the stalling. Good place to start!
Winter Rules
