Service Engine Light - Code P1175
Hi Guys
Trying to get ideas of what might be wrong with my car. 2000 540i/6 with ~126k miles. Short story is my check engine light came on. Took it to the local auto place and the code came up as P1175 (fuel trim adaptation additive bank 2 malfunction. Explanation: large vacuum leak on engine). What's happening is for the first few minutes after a cold start my idle is pretty rough. Every once in a while when the car is moving and I take out out of gear and don't have the clutch pressed the revs will drop to 0 and the engine will die. The problems go away as soon as the temperature gets to the normal running temp. I have searched around and everything I have found shows that P1175 is accompanied by P1174. I have yet to find anything that shows only P1175 being thrown, which is my case. From reading around it seems it could be anything from the MAF sensor to gaskets/o2 sensors. I recently replaced the alternator (for the second time, first replacement alternator went bad) a week ago or so and am wondering if the vacuum leak could have been caused by anything I may have taken off and not put back properly (specifically the air filter housing). My dad also decided he wanted to clean my MAF sensor just before I did the alternator. I am curious as to if there is the possibility of that being cleaned or re-installed improperly which could be causing the problem. tl;dr - CEL throwing code P1175 only. Any help or ideas would be greatly appreciated. Thanks! Last edited by necero; 01-17-2013 at 07:50 AM. |
How many miles on the pre-cat O2 sensors? If original, you're overdue for replacements.
You could also take it to a shop for a smoke test.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
I assume they are the originals, but am not positive. I have all of the service history so I could go digging and find out.
That p code by itself is pointing to your air mass sensor, likely contaminated. You are dead on in suspecting that your dad may have done more damage than good.
Either way I think I'm going to replace my pre cat O2 sensors, seems like something that needs to be done eventually anyway. |
- Mass air flow sensor (MAF) & idle control valve (ICV) require periodic cleaning (1) (2) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF) & cleaning the throttle body (1)
Edit: Am I correct in reading that the 99 and up model years don't have an ICV because of electronic throttle linkage? Last edited by necero; 01-17-2013 at 08:10 AM. |
Correct for the V8.
Thanks, just wanted to make sure. Just an update. At work I cleaned the MAF again and let it sit for a few hours before going home. When I started the car to head home the SES light was off. During my drive home, after about 5 miles or so, the light came back on. Would I be right in thinking that means it's a faulty MAF sensor causing my issues? I'm going to change out my pre-cat O2 sensors as well since they need doing, I just hate not knowing what exactly is causing the problem.
Thanks for everyone's help thus far. |
