E34 (1989 - 1995)
Old 01-16-2013, 07:55 PM
Canopy48 Canopy48 is offline
Mein Auto: BMW, minicooper and Nissa
Remote control for 525i
How do you reset the remote control for 525i 1995? Thank you in advance.
Old 01-16-2013, 08:56 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Do you mean how to sync it ?
Sent from my Desire HD using Bimmer App
Old 01-16-2013, 10:53 PM
Yes
Old 01-17-2013, 07:43 AM
Originally Posted by Canopy48 View Post
Yes
First do you have the the 3 button fob ? And if u do this is the procedure :
1 remove the cover to the fob .
2 slide the chip socket forward.
3 gently pull the micro chip out of its socket . This chip will be used for coding ur control unit .
4 remove the control unit from the bracket . ( its going to be under the back seat ) remember DO NOT REMOVE THE POWER CONNECTOR )
5 while holding the control unit facing donward , remove the access cover . Insert the micro chip into the units chip socket push the holder socket back to secure the chip .
6 press the reset button . The status led will flash twice to indicate that the code has been accepted .
7 remove chip and replace it back in the fob and your done
Hope this helps and welcome to the fest
Noel
Old 01-17-2013, 04:20 PM
Thank you very much for the info.
