Old 01-16-2013, 08:31 PM
Ghettobird209 Ghettobird209 is offline
Mein Auto: 2006 BMW 325i
Question E90 Speaker Placement Premium&non-premium
Hey all going to be buying a 06 330I with premium,sport&cold packages. also has Premium sound. I was looking up info on these cars and it says that stock it has 10 speakers? (1 sub???) and with premium sound it has 13? with 2 subs????? Ok so the car im going to be buying has premium.... but i did not see that many speakers!!!
where are they?
i seen 2 in both front doors, 1 in each back doors but thats it, althought i was more test driving the car and not looking at the speakers just wondering because i am 80miles away from the vehicle.
Thanks for your help in advance!!!
ALSO IS THIS A GOOD DEAL?
so the car is 06 330I like i said, premium,sport(sport suspension,seats&rims?) &cold. Premium sound.HID's, Navigation, park distance control , and some leather color i have NEVER Seen like almost a red but maroon(optioncode #LCB8???)???? idk its nice tho!!! it has 41,000 miles and a carfax report like no other!!!! it has had 10 oil changes sense day 1! which to me is amazing i have never actually seen a carfax like this! It has other great service records as well. It is priced at 17,500. Should i buy???? Thanks all!!!
Last edited by Ghettobird209; 01-16-2013 at 08:50 PM. Reason: adding option code for leather color via BMWVIN.COM
Old 01-16-2013, 08:59 PM
floydarogers's Avatar
Pedant and Curmudgeon
This has been covered many, many times; did you use the Search function?
In '06, the standard had 8 speakers, the HK/Logic7 has 13. Both have subs under the front seats; HK has center front speaker.
Old 01-16-2013, 09:02 PM
Yes i used search thanks for advice, nothing popped up. ok so thats 9 speakers were the other 4?
Old 01-16-2013, 10:50 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
For stereo info go here
http://www.e90post.com/forums/forumdisplay.php?f=27
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/showthread.php?t=343673
http://www.e90post.com/forums/showthread.php?t=138949
http://www.e90post.com/forums/attach...1&d=1209780605
http://www.e90post.com/forums/attach...1&d=1209780865
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...4&d=1278871872
Premium is the Hi Fi tweeters count as speakers. It has 4 4inch speakers and tweeters in the front doors
and rear area that makes 8 plus two 8 inch speakers one under each front seat.
Sounds like it has been treated well with 10 oil changes .
Most I see only get two or three based on millage and the computer based recall.
Wait I think I'm wrong all US 330's in 06 came with the L7(Top hi fi)or HK in the US as described in the above links which is 13 speakers with surround
sound. see links above for details.
To get a full list of options google the bmw vin number decoder and input . it will spit out all the factory installed options.
Top-HiFi System (option 677) on E90
9 channels, 13 loudspeakers
1 mid-range loudspeaker, middle, 100 mm
2 treble loudspeakers, front 26 mm
2 mid-range loudspeakers, front 100 mm
2 bass loudspeakers, 217 mm
2 mid-range loudspeakers, rear door, 100 mm
2 mid-range loudspeakers, rear shelf, 100 mm
2 treble loudspeakers, rear shelf, 26 mm
Bandwidth: 30 Hz to 20.000 Hz
Max. acoustic pressure: 110 dB
Amplifier power:
2 x 70 W (4 ***937 Bass
7 x 40 W (2 ***937
HiFi-System (option 676)
6 channels
10 loudspeakers
2 mid-range loudspeakers, rear, 100 mm
2 treble loudspeakers, rear 26 mm
Bandwidth: 40 Hz to 20.000 Hz
Max. acoustic pressure: 104 dB
Amplifier power:
2 x 40 W (2 ***937 Bass
4 x 25 W (2 ***937
The two known problems in the N52 engine are valve ticking and head bolt/valve cover
breakage
