New Member OH 614 04 330XI - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-17-2013, 05:56 AM
damadhatter damadhatter is offline
DaMadHatter
Mein Auto: 04 330XI
Recently purchased my first E46, here she is before.
and after
Let me know what you think. Every time I drive about 200 - 500 miles the oil light comes on, some times its yellow other times its red, I'm assuming red means the oil is severely depleted. Also I have that same issue that I just read about the recall for the tail lamps, bulbs just burn out every 2 months or so. Any advice will be much appreciated.
Old 01-17-2013, 07:08 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Red means something very different. Download your car's owner's manual here:
http://www.linquist.net/motorsports/bmw/3manuals
Old 01-17-2013, 07:34 AM
Dahlyla Dahlyla is offline
Mein Auto: 03 e46 awd premium packag
My 03 325xi did the same thing I have high miles so I switched from Castrol 5w30 to castrol 10w40, went from burning a quart per full tank to about a quart every three full tanks....
Sent from my NOTE II using Bimmer App
Old 01-17-2013, 08:03 AM
lgr122 lgr122 is offline
Mein Auto: '04 e46 Touring M-Sport
Pretty wheels! Would like that kind in mine also...
Old 01-17-2013, 08:07 AM
DaMadHatter
Mein Auto: 04 330XI
Don't have a good PDF reader but I have the physical manual so I'll check it out, I thought it was due to an oil leak, when I looked under the car it definitely showed signs of an oil leak that's why I assumed it would mean that. I'm going to spend some time with the car today and do a tune up / other minor maintenance. What I'd like to do is stop pouring oil every 200-500 miles and clean up the bottom end as to where there are no leaks. So if you guys know of any common problems I would love to know. Thanks!
Old 01-18-2013, 08:15 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Do you know a pdf reader is a free download?
Oil leak comes from VCG, or OFHG or less likely oil pan gasket. Burning oil is worn oil rings, or valve stem seals.
Or your CVV system is shot and needs to be replaced.
