E46 (1999 - 2006)
Old 01-17-2013, 08:14 AM
tae314 tae314 is offline
Mein Auto: hopefully a 01 325i
Help tons of codes, no idea whats wrong!
my 01 325i would start but would not run longer than a few seconds it would idle rough then die. i checked the codes and there was 13 of them.
p0171-bank 1 too lean
p0300 twice - random misfire
p1352-cylinder 6 misfire during startup
p1346-cylinder 3 misfire during startup
p1348-cylinder 4 misfire during startup
p1345-cylinder 2 misfire with fuel cut off
p1351-cylinder 5 misfire with fuel cut off
p0313 twice - misfire with low fuel
p0174-bank 2 too lean
p0175-bank 2 too rich
p0172-bank 1 too rich
it would run once i unplugged the maf. im thinking fuel pump or massive vacumn leak. any other suggestions would be great its my daily driver and i need it up and running asap.
Old 01-17-2013, 09:59 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Standard advice is to clear them, and then drive the vehicle, and watch to see what pops up as pending, and take the first codes first.
For misfires, all known culprits are listed here:
- How to diagnose a BMW M54 engine misfire (1) & how to battle M54 vacuum leaks (1) (2) (3) & how to solve specific vacuum leak diagnostic trouble codes such as P0171, P0174, P0313 (1) & P0170, P0173 (1) & where to find all the vacuum hoses in the M54 (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 01-17-2013, 11:19 AM
smolck's Avatar
smolck smolck is online now
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
I'd say vacuum leak for sure, possible fuel pump issue. You can rent a fuel pressure tester, there is an EASILY accessible port on the front of the fuel rail, takes 5 minutes to test.
I'd get a smoke test done too, or at least remove all the intake tract from the MAF to throttle body and check for cracks/holes.
Easy and effective first steps in troubleshooting.
Check out my BMWBLOG!
Old 01-18-2013, 04:53 PM
Did a fuel pressure test. It was very shaky at idle around 45-48psi and when I shut the engine off pressure plummeted. Also with just the pump on it would not read higher than 30 psi and would slowly drop. After this test I decided to go ahead and replace the pump. It's much more responsive but if plug in the maf it starts to idle rougher and rougher till the engine stalls. Going to check intake hoses and disa seal tomorrow.
Old 01-19-2013, 08:05 AM
smolck's Avatar
ROLL TIDE!
Sounds a lot like a bad MAF.
Old 01-19-2013, 09:59 AM
bluebee's Avatar
If it's the MAF, these may help the OP:
- Cleaning your mass air flow (MAF) sensor (1) (2) (3) (4) (5) and how 'not' to clean your MAF (1) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF) & MAF resistance testing (1)
