E34 (1989 - 1995)
Old 01-17-2013, 01:20 PM
S406 S406 is offline
Mein Auto: 00 S4, 93 525i
heater issue
My heat gets a little cooler at idle. It still blows warm air but not to my liking. The anti freeze is at its appropriate level and it is bled properly. What gadget is failing. I also dont get heat to the rear or passenger vents. I know nothing about these heater systems. Thanks
Old 01-17-2013, 01:28 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
flush your heater core
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 01-22-2013, 09:06 AM
flush the heater core as in the cooling system? What about the passenger vents blowing cold? Im thinking its the climate control dial?
Old 01-22-2013, 09:34 AM
BMWFatherFigure's Avatar
Old School
Why? No matter what temp you select, if you have an air lock or part blocked core the heater won't work..
Current:
Previous:
Old 01-22-2013, 10:28 AM
Im getting heat on the drivers side vents. No rear heat or passenger heat. Thats why I im suspecting the climate control for the pass side. The rear I have no idea....the vents blow cold. Im an lost in understanding the inner working of the heater on these cars. If I get heat through the heater shouldnt it blow heat throughout the car?
Old 01-22-2013, 12:35 PM
Old School
It depends on the construction of the core. The rear heat is determined by the driver's temp setting. Sounds like you have flap control problems inside the heater box. I don't envy you this one at all.
Current:
Previous:
Old 01-22-2013, 01:22 PM
lol well that sounds promising!! I have a spare I can throw in. Is it a PIA to replace?
