Old 03-22-2013, 05:02 PM
Atl..BMW.. Atl..BMW.. is offline
Mein Auto: 2004 745i
Dynamic Drive inactive
Dynamic Drive inactive has popped up twice in the last 2 days do anyone have any ideal on what it mean......
Old 03-22-2013, 05:12 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
Most likely a failing alternator. Check your p/s fluid level also
Old 03-22-2013, 07:36 PM
dannyb1027's Avatar
dannyb1027 dannyb1027 is offline
Mein Auto: 2008 528xi
There is a sensor located on the Passenger side Control arm. sometimes that Gets Seized And set The light. You can disconnect the lever from the control arm and see if it moves freely
Old 03-22-2013, 08:01 PM
Old 03-23-2013, 03:48 AM
Past Sponsor
Mein Auto: X3
You're gonna have to get the faults read by someone with a bmw scanner
Old 03-23-2013, 06:49 AM
gmcclintock's Avatar
gmcclintock gmcclintock is offline
Maintainin'
Mein Auto: 2006 750Li
It's probably your ASR Module or ASR Valve Block I had the same issue, I changed the Valve block and that corrected the problem. I wrote a DIY on how to change the Valve Block yourself if you are that kind of person. With that said take the car to a dealer or Indy to make sure it is in fact your Valve Block because it could be either or it could be both. Good luck
<div align=center>
85 Honda Accord(Sold), 93 Lexus GS 300(Gave to lil Bro), 96 Lexus LS 400(Sold)
03 BMW 525i(Traded/Sold), 09 BMW 750Li, 07 BMW 530i, 04 Pontiac Grand AM (Daily Driver), 08 Ford Focus (Wife's Daily Driver)
Old 03-23-2013, 09:07 AM
How can I find the DIY on how to change it. ................ I notice surges also....... Would that also be a symptom
