E46 (1999 - 2006)
Old 01-17-2013, 05:41 PM
BoofyBlitzed BoofyBlitzed is offline
Mein Auto: 1999 323i
Replaced Alternator???
I replaced my alternator this week and when i started my car my battery light was on. I checked the voltage at the post on the back of the alternator and it was only 12 volts when i first started the car and the more i ran it the lower it got. I checked the pulley and it was turning fine, and i have a brand new battery. the only thing i can think of is that i got a bad alternator from Napa?!?! any other ideas? I'd rather not yard out the alternator again just to find out its not the problem.
thanks for the help
Old 01-17-2013, 05:46 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
You should have 12.4 to 12.6 volts on your battery with engine off or your battery is not fully charged. You should have 13.6 to 14.0 volts once you start the car.
Check the voltage at your battery post, check all chassis grounds too. If they are good make sure you do not have parasitic drain/ a short somewhere pulling all the voltage to ground.
Old 01-17-2013, 06:02 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You have to start over on the diagnostics:
- DIY how to test a BMW battery & alternator
Old 01-17-2013, 10:16 PM
jmo69 jmo69 is offline
Mein Auto: 98 328is 2003 325xi
I feel your pain about removing the alternator again. I had to replace a new one I got from Advance because the bearing was bad. Take it out and have them test it, the weird thing about mine was the battery light never came on, even with the voltage low enough for the car to not crank.
98 328is Cosmos Schwarz Metallic 55w 6000K HID w/angel eyes smoked headlights, tails, corners, fogs and side markers Sparco strut brace, X-brace, Eibach Pro Kit springs, CAI, Prosport gauges, LEDs where ever they work, DDM pedals, 35% tint all round, HD lip, M3 style rear diffuser.
Old 01-18-2013, 06:42 AM
bluebee's Avatar
Same thing happened to me.
By the time the battery light came on, the car had already died in the middle of the road.
Full details (as always) here:
- One users' example of total electrical failure (AAA towed away) alternator repair (1)
[Read post #66 & post #107 & especially post #146 for M54 DIYs]
Old 01-18-2013, 11:16 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Don't care where you got the alternator from, but Bosch or Valeo replacement is a must. Anything else is going to fail faster.
