Old 01-17-2013, 07:42 PM
Gootz4u Gootz4u is offline
Mein Auto: 2001 540i BMW
My car misfires
When I turn on my car, it idles rough and I try to give it a little gas but when I step on the gas pedal the motor does not respond. When the car is finally warmed up the idel goes up to normal which is right under 1 RPM. A frined of my told me to idel the car at 4000 RPM to check the cats but I could not get it up to 3000 RPM. The idel kept going up and down up and down while I was pressing on the gas, then the car misfired a couple of times. I did notice when I was driving, I could not get it to move more than 20 mph and my check engin light was flashing. I have looked for vacuum leaks and I have found nothing. Could it be the AMF or the throttle body. Anybody got any ideas? Thank You for your help.
Old 01-17-2013, 07:59 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Sounds like a vacuum leak. Vac leaks are hard to find without smoke test. You can take apart the intake boots and look for a tear. If you find nothing, take the car to an indie who is a BMW expert and get a smoke test.
VF Supercharger Kit much modified & tuned by FS Tuning Tech,M5 Front Sports Seats,CVV to Catch Can Conversion,Boost Gauge, Schmiedmann S.S. Header to Rear Muffler High Flow Exhaust,Header Ceramic Coated Inside & Out,Heat Wrapped from Header Flanges to & Including CATs,Kicker Sub w/200 Watt Amp,CCFL Angel Eyes,Blackout Facelift Kidney Grills, Quaife LS Diff, Zionsville Super Duty Cooling Kit, EMP Stewart WP, Derale Electric Cooling Fan Ajustable Controller w/2 Speed Circuit (JimLev Design).
Old 01-18-2013, 06:06 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
The flashing amber check engine light indicates that expensive damage will be done to the vehicle emissions devices.
I myself have never encountered a flashing check-engine light - but I would take it seriously if I were in your shoes.
At the very least, I'd invest $25 in a scanner.
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
In addition, the OP needs to read this thread:
- How to diagnose a BMW E39 engine misfire (1) & a cold-engine intermittent misfire (1)
