Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-17-2013, 10:50 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
318i will not start, new starter?? Please help.
Hey guys, i have an unusual problem. I have been driving my car around until one day it didnt want to start. Long story short towed it home and it started right when i got home. This was a brand new starter mind you (3 months old) again it wouldnt start. I tested the blk/yellow wire from the ignition and it was reading 10.8-11.4 volts when te key was turned to start. So i exchanged the starter for another today and it still wont start? Im at my wits end!
The fuel pump relay does make noise sometimes and it seems as though it doesnt work. Also once the pumps stayed running even with key off. I had to pull the pump relay to shut them off. Does this scream a bad ignition switch and or loose connection?
Thanks for the help.
Old 01-18-2013, 11:46 PM
BMWFatherFigure's Avatar
Old School
Bad fuel pump relay for a start. Ditch it and lets go from there.
Current:
Previous:
Old 01-21-2013, 07:02 PM
onager onager is offline
Mein Auto: 87 E30 325i
What do mean when you say it won't start? Do you mean the engine turns over and doesn't start or do you mean the starter isn't turning the engine over? Another bit of helpful info is what year is your car and does your car have an automatic transmission.
If your car isn't turning over and you have a new starter you should check is the connections of the ground strap that goes from the starter to the chassis. The ground strap contact points get corroded or the strap strands get corroded and break which causes enough of a voltage drop that the starter won't.
Old 01-22-2013, 06:05 AM
Old School
I read it as turns but does not catch. That and the fuel problems lead me to suggest ditching the FPR. OP has not got back yet.
Current:
Previous:
Old 01-22-2013, 09:28 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
I read it as the opposite to you in that it doesn't turn at all. why would he replace starter or check for 12V on the infamous black/yellow starter wire
OP, please read here before reporting back
http://www.bimmerfest.com/forums/sho...d.php?t=597283
Old 01-26-2013, 07:37 PM
First time's Avatar
Hey thanks guys for the responses. I have actually already found the issue. My dumbass took the ground strap off with intentions to replace it with a new one. This is the strap that goes from the lower left part of the chassis to the top of the oil pan. Anyway i bought another ground and viola! Kick me now please.
Old 01-27-2013, 05:03 AM
Old School
Our pleasure!!
Current:
Previous:
