E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Clutch problem
I have a 1993 BMW 325is and the clutch pedal went to the floor I added more fluid and it seems to come back. I notice for some months that I saw some fluid on the drive way and never could figure out where it was coming form. So is there a way to determine if it is the slave cyclinder bad or the master cyclinder is back or both and what to do?
change both. sounds like the slave is bad
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Yea I'd say for sure the slave due to the fact that the master is actually inside the car on the clutch pedal. I replaced both of mine when my master went and i think they were pretty cheap.
Scott Boy |
I have recently replaced both the master and slave clutch cylinders...using pirate Chinese parts as OEM are much too expensive.
Now works fine but even with my small hands I battled to replace the master cylinder although I think it is worse on the RHD cars such as I have as compared to the LHD E30s in the USA. |
Mine did the same thing. I was not leaking fluid but mine fell to the floor, turns out it was the master cylinder. BTW just a heads up bmw seattle sent me 2 master cyl. gaskets so let me know if you'd like the one I didn't use. might save you a few bucks.
1987 325e 2002 325ci 1999 Aprilia Rs50 (80cc Kit) |
It was the slave it took me about 1 1/2 to replace mostly cause too my time and my car was hard to jack up
The master cylinder (for the clutch) will leak inside the car. Master and slave are easy to rebuild. Depending on model the clutch will share fliud from the brake system..
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
