Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 06-17-2012, 03:44 PM
cdmci cdmci is offline
Mein Auto: 740i
Navigation Disk Keeps Ejecting?
Has anyone else ever experienced any issues with there NAV Disk not staying inside? Mine constantly ejects for no reason at all.
Old 06-24-2012, 10:05 AM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
You didn't mention which Nav unit you have in your 7 (or what year your 7 is).
But, is your map disc an original one or a copy? Some people have had issues with copied maps not working correctly.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, Alpine DVD changer with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 06-24-2012, 07:57 PM
Mein Auto: 740i
SB, thanks for the reply. I have the MK3 currently in my 2001 740i. My disk is original OEM and I experiencing a few pixels missing on the screen. Do you think I should just upgrade to the MK4 and call it a day?
Old 06-26-2012, 03:33 PM
Personally, I'd try to borrow a known working map disc from someone else (or, have your OEM map disc put into a working MKIII from someone else) & see what happens.
Then, I'd swap (with a friend) that also has a working MKIII & see if his/her MKIII works fine in your car & your MKIII has the same problem in his car.
Those would be much cheaper test methods than just going out & buying a MKIV. But, my GUESS is a MKIV would solve your problem. I'd just want to be really sure your MKIII needs to be replaced before I'd spend the money for a MKIV (unless you want to upgrade to the MKIV anyways).
Let us know what you find out.
Old 06-28-2012, 06:58 AM
shled's Avatar
shled shled is offline
Mein Auto: 01 740i Dinan s3, 98 M3
Check the disk in sunlight for big scratches or swap discs with a pal?
...on the gas,
Shled
Charter Member
BMW E38 Real Beef Club
My car
Old 01-24-2013, 09:59 AM
CarloPel CarloPel is offline
Mein Auto: 2001 740i -Sport
I also have just had this issue, and have no clue why it started rejecting the disk. I tried two different disks, each of which used to work fine.
I first noticed VERY slow response from the nav system while trying to input a destination, then it completely stoped working.
How can I tell which nav unit I have? There doesn't seem to be any identifying labels that I can find..
Thanks for any help..
2001 740i Sport.
Old 01-25-2013, 09:49 PM
Assuming the Nav hasn't been changed out in your 2001 7, then if you have the smaller screen (4X3), then you have a MKII. If you have the widescreen (16x9) up front, then you have a MKIII in the trunk. If the Nav in the trunk has "DVD" on the unit, then it's a MKIV.
Old 01-26-2013, 04:13 AM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Try a head cleaning disc or blast of compressed air (carefully).
Current:
Previous:
HTML code is Off
