Old 01-03-2013, 10:12 AM
2k528i 2k528i is offline
Mein Auto: 2000 528iA
Burnt paper smell from vent as car warms up
Yesterday I had a burnt paper smell come into the car as it was warming up... I opened the hood and the smell is not noticable around the engine compartment. It is definitely coming from the vents.
As I drove it went away but then came back.. could a piece of paper have gotten against the heater core or something else?
Seems odd that it just started doing this, just driving back and forth to work so the car hasn't been any place unusual.
Any ideas?
2000 528i
Old 01-03-2013, 10:20 AM
OntheRock OntheRock is offline
Mein Auto: 530i
Assume you checked in and around the cabin air filters? There are a bunch of good instructions for changing these (very easy to do).
Old 01-03-2013, 10:23 AM
flyboyy's Avatar
flyboyy flyboyy is offline
I glow in the dark
Mein Auto: 2003 BMW 530i
are you sure its not.. burning oil smell ? its possible that oil leaking from your VCG that is getting onto the exhaust pipes and causing the burning oil smell to get into your cabin..
I had similar issue and I changed out my VCG and no more oil burning smell coming into my cabin.
Old 01-03-2013, 10:42 AM
cabin filters
I did check the cabin filters, nothing there.. and it doesn't smell like oil, and there is no sign of smoke.
Just the odor of burnt paper.
2000 528i
Old 01-03-2013, 01:17 PM
I have the odor of burnt 'something'. Very hard to pin down the smell. I wouldn't say it's paper, but, it's a sickly sweet burnt smell like nothing easily described.
I'd post a picture or video of it if I could - but - I'm assuming the only thing it 'can' be is burnt fluid.
The question is what fluid:
- oil from the vcg
- power steering fluid
To the OP: Look at the passenger side of your engine, near the front, just above the SAP valve and below the valve covers. Do you have oily gunk there?
Old 01-04-2013, 10:38 AM
nothing
Drove the car into work today and didn't smell anything so maybe whatever it was is gone... I have no idea.
Thanks for the suggestions everyone, if it comes back I'll update this post.
FYI, I did a search on this subject and found nothing.
2000 528i
Old 01-04-2013, 01:39 PM
I just ran an E39-only title-only search for "smell", and it came up with these:
This went on for four pages. I didn't read them, but, it's a pretty common issue.
Note: I didn't even start to search for "stink".
Old 01-05-2013, 12:11 AM
Jksearners Jksearners is offline
Mein Auto: 530d E39 & 320cd E46
Hi I started to notice a slight burning smell in my 2002 E39 when warming up and a couple of weeks later my blowers have stopped, took to garage and quoted silly money to repair. They told me its a common fault so I decided to research it and it does seem fairly common fault, I'm now in process of tackling the fault myself, although I'm not a mechanic, the never ending list of videos on YouTube should help keep me safe. good luck with yours
Old 01-21-2013, 10:50 AM
LinkA8A0A LinkA8A0A is offline
Mein Auto: 2002 525i
I have the exact same issue...when car is warming up I smell something burning through vents and under hood when outside of car. I can't tell what it is, though.
Old 01-21-2013, 03:24 PM
gomolka30 gomolka30 is offline
Mein Auto: 2001 530i
Sweet smell is almost always coolant. The best way I can describe its smell would be similar to maple syrup. If you don't see any leaks/steam in your engine compartment, then almost certainly you have a leaky heater core, or connections between your heater core and hoses.
I'm having a little bit of this myself. It only started happening after I slightly overfilled my coolant reservoir past "kalt".
Also if you notice that your windshield is fogging up more than normal, this is a tell-tale sign of a leak around the heater core.
Old 01-22-2013, 05:03 AM
Understood. It's a warm sickly sweet smell when coolant is splashing about the engine compartment.
The smell I have is sort of like plastic burning mixed with oil. ... (I'd post a picture of the smell if I could)....
Old 01-22-2013, 10:13 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: 2000 DINAN 540, 1983 745
Mine also smells like an oily coolant mix smell, and i have to top the coolant off every once and a while. I've done a coolant system over haul, except for the water pump, but why would i replace something that hasn't broke yet? I've also replaced my vcg, vanos seals, and am currently procrastinating about the vally pan gaskets. its just too cold to wanna get into that.
2000 Dinan 540 Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Powerflex polyurethane bushings, Dinan stage 2 engine software, Stage 1 trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, Dinan TB, AFE cai, 18" style 5's, 235/40/18 275/35/18, Ultimate cup holders, rear cup holder delete/coin holder, Hella taillights, clear sides, Depo AE, M5 spoiler
1983 745 turbo, style 138 wheels
Old 01-22-2013, 10:34 AM
mr magoo mr magoo is offline
Mice?
I found a mouse nest under the intake manifold when I was doing my VCG.
Old 01-22-2013, 10:39 AM
Coochie_Bandit's Avatar
Coochie_Bandit Coochie_Bandit is offline
Mein Auto: 540
Originally Posted by mr magoo View Post
I found a mouse nest under the intake manifold whan I was doing my VCG.
Lol. Wow. I cant imagine what you were thinking.
I Know I'd have a major WTF moment.
Old 01-22-2013, 10:49 AM
Funny you should mention that because I suspected one chewed my insulation here:
- One user's pictorial DIY for replacing the BMW M54 engine spark plugs (1)
