Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 01-18-2013, 03:34 PM
bob0947 bob0947 is offline
Mein Auto: 1998 740IL
Smile windwasher issue
I filled my window washer with fluid ran the car and the wipers work fine but the windshield washer fluid will not spray..is it a motor or fuse issue or clogged orifices?..thanks 1998 740IL 115,000 miles
Old 01-18-2013, 04:30 PM
Sobek Sobek is offline
Mein Auto: 1996 BMW 730iL
It's most likely just the washer pump that's failed - not a particularly hard fix, mine's dead too but I just haven't got around to replacing it. Check the guide here;
http://www.bimmerboard.com/forums/posts/182119
Good luck
1996 BMW 730iL
Old 01-18-2013, 11:14 PM
BMWFatherFigure's Avatar
Old School
Does the pump run? Bit hard to diagnose from here. If the pump does not run check for power and earth at the plug. If it does run then check the hoses and jets for blockage. You needed us for this?
Current:
Previous:
Old 01-19-2013, 02:17 PM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Its very common on all cars for a slime to form in washer reservoirs. Before spending on new pumps etc, check out the reservoir for clogged outlet filters. There is also a filter on the reservoir for the intensive headlight washer pump, which falls off if the pump is removed, so that unfiltered fluid can then block the headlight washers too....Its a very easy job indeed to remove this for cleaning/checking
Old 01-20-2013, 02:28 AM
Old School
Compressed air is very useful for these processes.
Current:
Previous:
HTML code is Off
