Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 02-05-2013, 02:05 PM
edge9 edge9 is offline
Mein Auto: 2013 E92 M3
oil sensor
At my 1200 service the car was overfilled by a slight amount, probably 200 ml. Of course there is no way to know this until the some oil is drained and the sensor can recalibrate. This is the reason for my post. This sensor when it is operating properly takes at least 30 minutes of running time to show changes in the oil level. This certainly happened to me when I had some removed but the sensor still showed High for miles before recalibrating. You can do a forced measurement once the engine is warm but this is not as accurate.
Be a Man, Use your Stick
Old 02-11-2013, 01:06 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
And to think that a sensor would be better than a traditional dipstick
Once a 6'er, always a 6'er.
Old 02-11-2013, 02:29 PM
+1 Exactly
Old 02-12-2013, 11:03 AM
captbilly captbilly is offline
Mein Auto: e90 M3
Service does not like to top it off because....
Your level is completely OK, about 1/2 liter low (or above the minimum, depends on if you are a half empty or half full kind of guy), so you don't need to do anything. The reason that most dealers only fill to this level is that if they even slightly overfill, or if the level sensor changes a bit and now indicates an overfill, they have to drain all the oil and start over again. If you have checked your oil level sensor much you will notice that it move around a fair bit from time to time, so the dealers are now very wary about getting near the top lest the reading go over the top and throw an error message (so they have to drain it).
My issue is that the car does burn some oil (about a liter every 8000 miles) and the oil is very hard to find (not to mention being insanely expensive) so I don't want to be stuck 200 miles from anywhere that I can buy the oil when I am low on oil. I always ask the dealer to give me an extra quart of oil to put in the trunk so that I can top off when needed. So far that extra quart has been enough to get me to the next oil change, even though the car came back from the dealer with 1/2 liter below full.
