The X5 SAV Forum
Old 01-19-2013, 06:02 AM
Buzz110 Buzz110 is offline
Mein Auto: 2006 BMW X5 4.8is
Loud Bang During Hard acceleration
I have a 2006 X5 4.8is. During a hard acceleration from a stopped or rolling position my vehicle sometimes makes a load bang noise emitting from the rear. I have recently replaced the subframe bashing with polyurethane ones and also two rear differential bushings. Does anyone have any other suggestion? Are there any other common problems that I can look into?
Old 01-19-2013, 12:30 PM
TechWrench TechWrench is offline
Mein Auto: '99 540i, '02 X5 3.0i
Do a search on it, but it sounds like it could be the main drive chain inside the transfer case. It is a known problem with these chains stretching with time, and under acceleration they jump a tooth on the sprocket, making the noise.
Old 01-21-2013, 06:01 AM
Thanks I will definitely check that out.
Old 01-21-2013, 10:05 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E53, E60, E92
2006 X5 uses XDrive, no longer has chain in xfer case (those are for pre 2004 X5).
Old 01-21-2013, 03:10 PM
Thanks, i have an '02, and didn't know about the change.
Old 01-23-2013, 06:58 AM
Any other suggestion then.
Old 01-23-2013, 09:25 AM
The common problem with X5 6-sp is bang noise during tak-off or stopping (like being rear ended from behind), dealer usually re-program the trans to smooth that transition.
