Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread.
Old 01-19-2013, 06:10 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Power & Torque Setting
I did a search without any luck. How can I change the Power & Torque measurements in the Sport Display. I had it and for some unknown reason it went to Kilowatt-Hours & M's. TIA
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 01-19-2013, 07:17 AM
Elk Elk is offline
Mein Auto: ~
via coding
Old 01-19-2013, 07:44 AM
FrogmanF30 FrogmanF30 is online now
Mein Auto: 2012 328i
cheers
vern
If you previously showed HP/Ft-Lbs, then see if the power units are available in the Settings -> Language / Units menu. If so, you can change it back there.
Usually, you will only see the power unit options if you code HU_CIC / 3000 HMI / EFF_DYN_SPORT_UNIT to aktiv.
Old 01-19-2013, 07:53 AM
Thanks, I'll see if they are there.
cheers
vern
Old 01-19-2013, 02:17 PM
Thumbs down
Checked the settings,nothing there.
cheers
vern
Old 01-19-2013, 09:15 PM
Sorry.
This unit problem seems common on ED cars. BMW service should be able to reset it to US units. If not, it can definitely be coded. I've done this on 2 other ED F30's so far.
