Old 02-06-2013, 12:15 PM
specialeffects specialeffects is offline
Mein Auto: 750i
Help a dude out
Hey everybody, so I have a 2007 750i with 38k miles on it. I live between Mexico City and Belize so it's a car I rarely drive. The wife and I decided to go to Acapulco for the weekend, 240 miles each way, got there without a glitch. About 180 miles on on our way back the car abruptly lost power and I pulled over on the shoulder. The rpms fluctuated between 400-600 and would not go up even when flooring the accelerator, all it did was sputter. After about 10 minutes I decided to turn the car off, left it for about 20 mins and restarted and took off with no problem, ran fine for about another 20 miles and did the same thing again, shut it down again for a few mins and ran fine. The rest of the way home traffic was bumper to bumper so 20mph the whole way. Any help would be appreciated
Old 02-06-2013, 12:26 PM
mrbmwx5 mrbmwx5 is offline
Mein Auto: 06 750Li
The best way to find out is get the car in for codes check.
2001 X5 3.0i 200k miles & counting...( SOLD)
Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights
06 750Li with 19k miles.
Bone stock.
Old 02-06-2013, 12:31 PM
Mein Auto: 750i
Yeah, I have an appointment at the dealership tomorrow, can't say I trust them tho, have heard many horror stories here, and besides they don't keep anything in stock for the 7's, took it in a couple months back and all they were able to do was change the oil, had to order the air and cabin filters online.
Old 02-06-2013, 01:25 PM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
outch stealership...
sounds like the seals dried out for the cam adjusting unit since you rarley drive it the oil stays at the bottom , therefore the seals in your
valvetrain dry out ..
goodluck
Old 02-06-2013, 02:26 PM
Mein Auto: 750i
Thanks for the reply Alpina, I noticed that the check engine light was on before we left home and its still on, would the seals being bad trigger the check engine light and how big of a job is it to have the seals replaced?
Old 02-06-2013, 03:10 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
right there is your problem. Good luck
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 02-06-2013, 04:32 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Sounds like a clogged catalytic converter to me. Get the codes pulled.
Old 02-06-2013, 09:11 PM
Busurfer's Avatar
Busurfer Busurfer is offline
Honey Badger 2.0
Mein Auto: '08 750Li
It could also be the throttle body, I just replaced that whole assembly last month. Symptoms were very close to yours although I got the visual warning image of an engine with a diagonal slash through it and "Reduced Engine Power" under it.
Life is too short for bad tone or crappy cars.
Old 02-07-2013, 09:13 AM
what amg?
before you jump the gun most european cars run like crap because of vacuum leaks
get the codes checked and proceed from there
the dealer will tell you alot of things to scare you
mind you that they have big overhead remember that when theyre "upselling"
second opinions are awesome
Old 02-07-2013, 09:32 AM
Mein Auto: 750i
Taking it into the dealership in a bit, will get a printout of the codes and post it when I get back. Thx for the feedbackso far guys, greatly appreciated
Old 02-07-2013, 11:59 AM
Mein Auto: 750i
Angry
Woo saa, deep breaths count to 10. Ok so just got back from the stealer, they said that they would need to keep the car for a minimum of 2 days to check everything, and they can't just do a diagnostic and give me a printout of the codes. Any suggestions on what type of scanner or code reader I could buy so that I could get the codes on my own? Thx
