Old 01-19-2013, 07:10 AM
darinbrooks darinbrooks is offline
Mein Auto: 2000 528i (E39)
Power steering hoses leaking at reservoir
I have a 2000 528i (E39). The power steering hoses are leaking at the reservoir. I replaced the hoses. And the reservoir but the hoses are still leaking. I have gradually been tightening the hose clamps but I am worried that if I tighten them any more that I will break the reservoir. Is there something that I am missing here? Is there suppose to be a seal (washer) or something between the hose and the reservoir?
Darin Brooks
2000 528i E39
Old 01-19-2013, 08:12 AM
Fudman's Avatar
Fudman Fudman is offline
The reservoir itself may be compromised. The standard fix for leaking power steering hoses is to cut 1/2" of the end of the hose and then reattach the hose with a new hose clamp. If you replaced the hoses already, I would check the reservoir itself.
Old 01-19-2013, 08:27 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
There are no seals, just a standard fit with a clamp.
When I replaced my hoses last year, I used clamps that are used for fuel injection hoses. I'm still using the original reservoir. The hoses are not leaking at the reservoir.
You might try tightening the clamps. If you still have the old reservoir and hoses, you may want to experiment with those to see how much you can tighten the clamps without breaking the reservoir.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-19-2013, 09:51 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Lots of information can be found by typing /power steering F3 into the bestlinks:
- Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1) & how to clean the power steering fluid reservoir internal filter (1) (2) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush cloudy ATF fluid (1) (2) (3) (4) (5) & what PS fluid to use (1) (2-pdf) (3-volume) & what volume is needed to buy (1) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5) & how to debug common BMW power steering issues (1) and noises (1) (2) (3) or steering rack noises (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 01-19-2013, 09:48 PM
mike530ia mike530ia is offline
Mein Auto: 01 530ia
I did exactly what Bluebee's post shows yesterday, and so far so good.
BMW front/rear aero lip spoiler| Custom Black & Tan Interior(still in progress but getting there) | Bilstein sports | H&R sport springs (nice drop, but has a slight rake | M5 rear sway bar (a must) | DDM 3000K Yellow Fogs | M5 rear lip spoiler | Ipod DICE kit | AFE Pro Dry air intake | 18" Beyern Mesh wheels | Umnitza FX-R headlights 55W w/Orion V2 Halos | Black-out grill & window trim | Silver gauge rings | Beisan Vanos Seals | 245/40 Bridgestone RE970AS | rear cup holder delete
Old 01-19-2013, 11:05 PM
professorman professorman is online now
Mein Auto: 2000 525i
I have a power steering leak which I need to diagnose as well. I just washed my engine last week so that I can find the exact origin of the leak.
2000 528i w/steptronic
Old 01-22-2013, 01:36 PM
Wheat7588 Wheat7588 is offline
Mein Auto: 540i
Holy **** i need to do this too. I have a pretty bad leak as well. Good write ups Bluebee!
2000 BMW 540i M Sport
6 Speed Manual
Clear Side Markers
Black Kidney Grills
Cellis LED Taillights
Others coming soon!
Old 01-22-2013, 02:23 PM
bluebee's Avatar
Not me.
Cn90 did all the DIYs and pictures.
I just re-appropriated them.
Old 03-15-2013, 02:23 PM
I realized that mine had a screw clamp on it. The clamp was loose, and the hose could be rotated on the nozzle. I tightened it up. Do you think that I still need to cut off a 1" piece of the hose?
Old 03-15-2013, 04:38 PM
bluebee's Avatar
I'm not sure 'why' we cut off the end pieces.
Presumably they're damaged, crushed, deformed, etc.
So, if yours isn't, then, i would think, it will be just fine.
However, time will tell ...
What YOU should do, to pay us back, in a sense, is to snap a picture of YOUR repair, and post it, so the next person benefits from your efforts.
Old 03-15-2013, 06:20 PM
AH673000 AH673000 is offline
Mein Auto: 1997 BMW 528i
Cutting a 1/2 inch off the existing hose end will eliminate the deformed ( by time ) end and give you factory fresh fit again . The shortened hose should fit on very tight vs the loose fit of the old fit up. It will last you another 10 years.
Old 03-17-2013, 08:40 AM
True. I will start snapping pictures on repairs that I do. Thanks for the reminder
Old 03-17-2013, 08:44 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
The 1/2 cut lasted only about 1 or 2 years on my PS hoses, at which point I had to change them with new ones. They started to sweat ATF, so nothing would hold this off. This method bought me 2 years of extended life of the PS hoses though
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 03-17-2013, 11:23 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
I last did this 7 years ago (May 2006), still good no leak.
What happens is as time goes on, the rubber hardens and the sealing effect is less than perfect.
professorman, don't remove 1 inch, all you need is removing 1/2 inch. This way you bring in "fresh" section of the hose for clamping.
