E36 (1991 - 1999)
Old 01-19-2013, 11:58 AM
the_duke the_duke is offline
Mein Auto: Z4 and 328
Question Secondary Air Injection System
The problem began with a noise that sounded much like a whimpering dog behind my dash when I had a cold start-up. From inspection I was able to ascertain the noise was coming from the secondary air injection system. Shortly after this the noise stopped but now the check engine light has appeared. I removed the injection system this morning and it appears to me the motor has burned up. It was quite charred on one of the leads and there was some soot/melting inside, not to mention the burning smell. While I intend to have the code pulled I am wondering how common such a failure is. Mainly do I have air out flow problem/exhaust that would cause the system to become over burdened and burn up?
It is a 1996 328 so considering the age of the car I'm not sure if my catalytic converter is gummed up since it happened on a previous vehicle of mine that was about as old. I live in a rather humid climate next to the ocean. Thanks for any advice.
-duke
Old 01-19-2013, 06:26 PM
EfiniMotorsport EfiniMotorsport is offline
Mein Auto: BMW 328is, 95 Jeep
If you pulled the secondary air pump you will throw a check engine light. Instead of replacing it do a search on here or bimmerforums for a SAPSIM. It is a simulator that wires in and makes the DME think the air pump is still there. Much cheaper and one guy is even selling a no splice kit.
Old 01-21-2013, 10:56 AM
The check engine light came on before I removed it but I'm pretty sure it was already fried. Thanks for the advice.
Old 01-21-2013, 02:47 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
what codes were set??
df
Old 01-21-2013, 03:06 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
The simulation is for states that do no emissions testing.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-21-2013, 07:32 PM
The simulators should still work to pass the sniffer test. If they do a visual and the tech knows what he's looking for you'll fail but those guys aren't usually the smartest. Unless your in CA you'll probably be ok.
