Old 10-11-2015, 06:29 PM
daf290 daf290 is offline
Mein Auto: 2007 650 I
Light Module Programing?
I replaced the headlights and I have an error with the headlights since.
I can make them move up and down and side to side by using INPA but INPA gives me the error code saying it cannot communicate with the LCM. Can anyone tell me what I can try next to solve this problem? I am out of ideas short of changing the LCM but I am quite certain it is ok but maybe needs to be reprogrammed.
I have attached the current error codes I get from INPA.
I checked the VIN of the LCM using NCS and it appears to be correct.
Name:	error adaptive control module in INPA March 23 2015.PNG
Old 10-11-2015, 09:48 PM
Dallasboy1985's Avatar
Dallasboy1985 Dallasboy1985 is offline
Mein Auto: Bmw E60 535 "10
Did u get a used headlight assembly with the controller ? I was getting adaptive malfunction msg , had to change the adaptive module/controller and the error was gone.
Old 10-20-2015, 10:49 AM
Changed Controller, no help
I got a replacement light module that goes on the headlight for control of the adaptive features. I replaced the module on one side with no difference.
I can get the lights to go in all directions by usiing INPA test functions so I think all is working in the lights themselves.
I also verified that the light control module located under the dash on my car is the correct part number and appears to be working correctly.
Does anyone have any ideas of what I can do next to try to repair this problem?
Thanks,
Doug
Old 10-20-2015, 04:01 PM
Jtbgonesailing Jtbgonesailing is offline
Mein Auto: 05 530i & 81 320i
The LCMs is pretty advised in that it will turn off individual circuited within a headlight assembly, if it detects a problem. The headlight modules have a track record of wireing insulation breaking down and allowing wires to short out with one another. If the LCM detects a short on a individual circuite 10 consecutive times, the LCM shuts that circuite down and it remains powered down until the counter within the LCM is reset. Just a thought... Believe tool 32 would be used to reset the counter. Good luck!
