7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Navigation and Radio problem, not working. Broken! Tried MOST fiber bypass. PICS!!
Here's my problem:
"BMW" is only displayed (PIC#1)on the navigation screen (unless I break the MOST fiber loop-more info later). Wont do anything! No radio, chime, voice control, ect. I tried that trick to bypass modules (ASK CD player, Voice Controller, CD changer, L7 Amp, Tuner) to exclude them from the MOST bus but not seem to be gaining any ground. I took that factory fiber loop from the glove box to bypass these modules..... FYI: I did not have to purchase a spare, I just took the loop connector apart and connected the two end together (the fiber ends in the glove PIC #3)-this seemed to do the trick. It seems if ring bus is broke the red LED does flash, when connected red LED stays light. I took the actual fiber optic line out of the connector housing and used it for bypassing. ......1) when I used the 'fiber loop' to bypass any the modules in the trunk and including the ASK or CD changer in the dash (PIC #5), nothing happens. 'BMW' logo will still be displayed on the screen. 2) when i take any of the modules out of the network ring (unplugging ANY of the modules-not 'bypassing' anything) I DO GET the 'accept' prompt on the nav display (PIC#7) and can navigate through some functions but can operate only the climate functions. No Nav(PIC#8) or radio (PIC#9), chime, ect. I can only scroll through. 3) I also tried that trick to go into the MOST diagnostic screen (PIC#10), but nothing comes up under the 'MOST' menu. Again, the only way can control anything on the Nav display is when the MOST fiber ring is broke. If I try to connect the fiber ring back together at that point, it will just freeze on whatever is display I have up. 4) Nav disk DVD does seem to spin and eject fine. Although I have noticed it will still spin when the ignition is off. 5) Dash CD player seems to a spin the CD, but no sound of course. 6) CD changer tries to eject a the cartridge. But it never worked anyway. 7) All the modules seem to be transmitting light via the fiber. Basically, the 'BMW' logo stays on when everything is connected and I cant do anything. I got my whole car torn apart and need some advise on what to do next? Do I need some software to reset the ghost errors after bypassing each module? Last edited by resistro; 01-19-2013 at 05:34 PM. Reason: update |
Get a new loop jumper and bypass navi and everything will work. According to pic3 you lose lots of data. You thought you saved 30$??? Really??? I'm impressed Your FYI failed Last edited by SFbay; 01-19-2013 at 08:34 PM. |
Like I stated, I already bypassed the NAV and it didn't help..
FYI: i wasn't trying trying to be cheap. Just wanted to let people know you don't have to go threw the trouble to buy a bypass loop when there is already one there you can use when your smart about it. Looks like you failed DUDE |
Pssst Hey Resistro...when you take the fiber loop out the glovebox to use to check other stuff..............YOUR STILL BREAKING THE LOOP (hence calling it a loop) Its not a spare...its also part of the system.
Nothing major 07 750Li (waiting for spring to put chrome 128's on) 00 S500 98 Tahoe 94 GS300 |
Instead of saying "thank you" I hear Fk off?? Ok, good luck and stop asking for advice then! Last edited by SFbay; 01-31-2013 at 11:35 PM. |
I had the same problem with mine... My CD Stacker in the dash was jammed... I pulled the unit out, and opened it up to get the CD Mag out of the unit... I somehow, ruined the unit, and I lost stereo, Nav, time... The lot...
I got a replacement unit, and it all works again... |
FINALLY solved it, my 'BMW' logo stuck on the Nav. It was the ASK unit. 100% sure. I decided to reset the Bat. every time I bypassed a MOST unit with the fiber jumper. When I got to the ASk unit the Nav came alive (of course no sound or Nav options cause ASK was bypassed). So I took the ASK apart and re-flowed the soldier connections and WOW it started working normally again!! Radio, Nav, Voice-everything is working now. Didn't even have to buy another one!
The ASK unit also controls some diagnostic functions it is considered the Connection/Network/Audio master. So when it was down I could not even use INPA to check any error read-outs of any of the MOST units so I could not narrow it down to a specific unit. )f course now, I can see all the units. So glad that problem is over with! Last edited by resistro; 04-06-2013 at 08:37 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
