E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Replacing coolant on 2000 Z3 Roadster
Looking for the simplest way to pefrorm this task. Hoping there is one.
Can I simply drain system from below (collecting old fluid), and then add clean water to system from above with the drain plug still removed and the engine running (heat on)? I was told that this would be sufficient. Next step to replace drain plug and fill with 50/50 mixture until full (approx 2 gallons). As always, thanks in advance. This forum is an invaluable resource. Scotty |
There are many threads here on this topic. You should look through some of those. Near the top of the page, on the right, is a button labeled "Search this Forum." Click that and type something like "coolant". That will help.
Rather than just replacing the coolant, you should consider replacing all of the plastic parts including the water pump, water pump pulley, thermostat, thermostat housing, radiator, reservoir, and hoses. These are getting old and brittle, can fail catastrophically, and can quickly destroy the aluminum engine. The way to change the coolant is to drain the radiator and drain the engine using the plug on the exhaust side of the engine by the number 2 cylinder. It's a messy job and coolant will run everywhere. Put down cardboard first. Have on-hand a new crush washer for the engine drain. Then fill the system with 50/50 coolant/water. Then you have to carefully bleed the system. That is done with the front of the car high, engine warm and above 1000 rpm, heater on. Squeeze the top hose to help expel the air. Again, there are detailed instruction available by searching. Running the engine with the drain plug out, even while adding water, is very very risky and unnecessary. If insufficient coolant is available, the engine will be destroyed. There will also be water trapped in the engine block that will dilute the coolant that you will add. It is best to drain the radiator and block then refill and bleed the system. |
Blacklane,
Thnx so much. I am always amazed at how people with knowledge of these cars are willing to go out of their way to share it, and help others like me. Much appreciated. Quick question: Can I reach the drain plug without raising the car too much? Supposed to reach 47 degrees here today, and I hope to take advantage of the sunny weather. Best, Last edited by SDFarrell; 01-20-2013 at 06:43 AM. |
BELTS Ribbed V-Belt, alternator, pump Ribbed V-Belt, AC compressor Adjusting (tensioner) pulley COOLING SYSTEM REBUILD Radiator Brass bleeder screw Coolant Fan shroud fasteners Radiator Gasket ring for temp. switch Radiator cap Expansion tank Gasket ring under exp. Tank See Radiator/tank combo (BavarianAuto) Water Pump & Thermostat Water pump O-ring for water pump Thermostat w/housing Axial gasket for thermostat Hoses Upper radiator hose - right Upper radiator hose - left Lower radiator hose Hose on top of plastic heater pipe Hose on end of plastic heater pipe Double hose on plastic @ rear head Plastic Connectors Plastic connector pipe on block O-ring for block connector Plastic Y connector on head O-ring for Y connector Manifold Lower intake manifold gasket Upper to lower intake man. gask. Block coolant drain crush ring Last edited by vintage42; 01-20-2013 at 06:56 AM. |
To SDFarrell: Yes, you only need to raise the car high enough to get your head under it to see where the drains are. The drain on the side of the block is pretty high. The drain in the radiator is pretty low.
To vintage42: this I a pretty good list. I can't tell from your descriptions, but be sure to replace the two plastic fittings on the 1.9 engine. One is in the back and is hard to see. For my job, I also added an aluminum thermostat housing and aluminum water pump pulley. I would also add the plastic fan to your list, although I converted mine to an electric SPAL fan and mounts from Fanman.com. You might also need the two radiator clips, which are easy to break, and the four rubber radiator mounts, which may have deteriorated. I replaced all of my belt tensioners and idlers which for the 2.8 with AC is 2 tensioners and one pulley. The 1.9 is different. You will probably need new hose clamps, particulary the small ones which are one-time use. You might need a fan holding tool and wrench. (Remember, it's left-hand thread). Finally, I replaced my block drain plug with a magnetic one from e-bay, but that probably makes no difference. I just bought it along with a magnetic oil pan plug. Last edited by Blacklane; 01-20-2013 at 06:58 PM. |
www.fanman.com is a ceiling fan company.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Coolant should be changed every 3 - 4 years, no matter the mileage.
Which reminds me, I need to do this on more than one car.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
