E34 (1989 - 1995)
Old 01-19-2013, 06:21 PM
fryntyr fryntyr is offline
Mein Auto: 1991 BMW 525I
1991 525I no start and front end parts interchange. Just bought
First of all just a reminder as a few of you have helped me with my prior 91 525I idle issue then my wife was rearended and the car totaled just after I got it running sweet.
I bought the car back from insurance for $500 and have been looking for a nice body to throw thow the low mileage engine into.
Item #1: Early this week I found a prtty nice Grey 91 525 with black interior. Owner knew nothing about cars and said the car just wouldn"t start. I bought it because the body and interior were nice with the thought of using the other engine. It cranked over great but no pop so I was hoping for a fuel pump issue. Worked on it today and pulled the tank pump access cover off and pulled the pressure line off. Then turned on the key,----nothing. Then pulled the relay and used a jumper wire just in case the relay was bad, still nothing.
So I pulled the pump out of the wrecked car, reinstalled in the grey one and the car fired up and is running sweet. Had to replace the valve cover gasket as it was leaking (done) and couple other small items but think I scored on this.
Item #2: I still have a parts car with great running gear and he rest of the body parts to use. I found a 95 wrecked in the nose and was wondering if the grill would work. The bumper didn't receive any damage and either did the fenders. Looks like it rear ended a truck with a hitch. If the 91 parts will work on the 95, I can use the hood, grill, core support and radiator? Car is pretty nice and is a manual 5 speed car. Your thoughts??
Thanks,
Old 01-19-2013, 07:05 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I think you scored HUGE no the $500 no start car. I keep looking for one like that around here.
As for the 91 and 95 swap on the hood, I thik as long as you swap the hodd and front grill, it should work.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-19-2013, 10:26 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
The hoods interchange. Its whether you want the lines of the hood to match the grille. Great on getting it started
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
